Nah, just the Bass boost circuit. The FET's are normally on, and exhibit a low impedance path effectively shunting/shorting out C15, and C16, when the switch is pulled, the negative voltage from the bias supply gets applied to their gates, and turns them off, C15/C16, now effectively are the lower impedance path to AC signals, and are shunted to ground creating passive bass boostnovosibir wrote: They've also introduced some kind of solid state clipper after the 5-th gain stage, still before the Master.
Check the attached schem!
Larry
Cameron mod
- joey
Re: Cameron mod
- Groovenut
Re: Cameron mod
You've gotta love obsolete technology...
- Groovenut
Re: Cameron mod
Horrible waste of a tube if you ask me....joey wrote:Nah, just the Bass boost circuit. The FET's are normally on, and exhibit a low impedance path effectively shunting/shorting out C15, and C16, when the switch is pulled, the negative voltage from the bias supply gets applied to their gates, and turns them off, C15/C16, now effectively are the lower impedance path to AC signals, and are shunted to ground creating passive bass boostnovosibir wrote: They've also introduced some kind of solid state clipper after the 5-th gain stage, still before the Master.
Larry
Re: Cameron mod
Id love to know how you wired that. Did you loose the normal channel on the plexi?briango wrote:A quick clip of the amp I was working on before this thread started, but none the less inspired from listening to clips. It is a 50watter that is switchable from Plexi/JCM800/AFD/Modern. This is just 3 gain stages with a footswitchable boost.
Re: Cameron mod
i have a question regarding plate driven tone stacks......
1. are you supposed to have a coupler coming off the plate before driving the TS?
2. what is this caps purpose, as ive seen many with and without it? is it a more biting tone without it? should i keep it or ditch them?
3. on this amp im working on, on the input it has a 33k into a 100n cap with a 470k to ground then to grid, what kind of input circuit is this? im working on my peavey valvking, so im trying to marshallize it a bit. ive since replaced it with the classic circuit, but im just curious about a few of these things....this is not a stock amp by any means, so any info is needed......
"purple power rules"
- darkbluemurder
Re: Cameron mod
Ad 1 and 2: no, a coupling cap is not necessary here since in a FMV tone stack, the treble, mid and bass caps take the function of blocking DC. Sometimes amp manufacturers use a separate coupling cap to allow them to choose tone caps with lower voltage ratings. If the main coupling cap is large enough you will most likely not hear a difference, otherwise the cap will introduce a bass reduction.
Ad 3: 33k = grid stopper to eliminate/reduce radio frequency, 100n = cap to prevent the scratching volume pot syndrome if there is any DC on the tube grid, 470k = grid leak resistor, which is needed as a ground reference for the tube grid. For this purpose it must be placed after the 100n cap.
Cheers Stephan
Cheers Stephan
- Jeremy1283
Re: Cameron mod
this sounds great sir!univalve1234 wrote:Hey guys , this is my take on the Cameron mod , i have added a 4th tube and tweaked the preamp and power section to get as close as i could . Let me know what you think.
Re: Cameron mod
Pandora UK
Nike Shoes
Nike Sneakers
Nike Outlet Store Online Shopping
Nike Basketball Shoes
Pandora Charms Sale Clearance
Nike Sneakers For Men
Valentino
Nike Outlet
Air Force Ones
Jordans Sneakers
Kevin Durant Shoes
Adidas NMD
Pandora
Nike Factory
Adidas Ultra Boost
Nike Zoom Pegasus
Air Force One Nike
Air Jordan Shoes
Louboutin Shoes
Nike Clearance
Nike Shoes
Christian Louboutin Shoes
Golden Goose
Kyrie Irving Shoes
Adidas Sneakers
Air Max 98
Jordan Retro
Lebron Shoes
Nike Running Shoes
Pandora Canada
Yeezys Boost 350 V2
Yeezys
Pandora
Nike Clearance
Nike Running Shoes For Men
Nike Factory Store
New Nike Shoes 2019
Louboutin Outlet
Nike Cortez
Womens Nike Shoes
Nike Sneakers Sale
Cheap Nike
Nike Running Shoes For Women
Yeezy
Red Bottom Heels
Yeezy Boost 750
New Nike Air Max 2019
Jordan 11 Blue
Nike Air Max 720
Sneakers Website
Yeezy Boost 350
Nike Air Max 95
Adidas Yeezy Shoes
Nike Lebron 16
Air Force 1
Yeezy Shoes
Nike Shoes
Air Force 1
Ferragamo Belt
Air Max 95
Nike Clearance
Pandora Canada
Red Bottom Shoes
Nike Presto Women
Fjallraven Kanken
Nike Outlet Store
Pandora Bracelets For Women
Air Jordan Retro
Nike Air Zoom Pulse
Nike Air Max
Christian Louboutin UK
Yeezy 500 Utility Black
Lebron 16
Red Bottoms
Pandora Canada
Red Bottom
Louboutin Heels
New Nike
Jordan Shoes For Kids
Nike Outlet
Ferragamo Shoes
Air Max 98 Gundam
Christian Louboutin
Nike Free Run
Pandora Earrings
Ultra Boost
Nike Uptempo
Pandora Jewelry
Adidas Stan Smith Sneakers
Nike Shoes 2019
Lebron 17 Low
Yeezy Boost
New Nike Shoes
Pandora Bracelets
Pandora
Air Max 720
Nike Air Max 270 Womens
Nike Outlet Store
Pandora Ring
Nike Black Friday
Jordan 11 Retro
Nike Shoes For Kids
Adidas Yeezy
Louboutin shoes
Pandora Jewelry Official Site
Ferragamo
Nike Factory Outlet Store Online
Mens Nike Shoes
Nike Cortez Men
Fjallraven Kanken
Jordan Retro 13
Louboutin Outlet
Asics
Kyrie Shoes
Nike Factory Store
Pandora Jewelry
Pandora Necklace For Women
Vans Shoes Outlet
Nike Huarache
Adidas NMD
Moncler UK
Air Jordans
Nike Factory Outlet
Nike Shoes
Nike Factory Store
Nike Free
Nike Outlet Store
Nike Factory
Jordan Retro
Lebron James Shoes
Nike Shoes
Nike Sneakers
Valentino
Nike Outlet
Air Force Ones
Jordans Sneakers
Kevin Durant Shoes
Adidas NMD
Pandora
Nike Factory
Adidas Ultra Boost
Nike Zoom Pegasus
Air Force One Nike
Air Jordan Shoes
Louboutin Shoes
Nike Clearance
Nike Shoes
Golden Goose
Kyrie Irving Shoes
Adidas Sneakers
Air Max 98
Jordan Retro
Lebron Shoes
Nike Running Shoes
Pandora Canada
Yeezys Boost 350 V2
Yeezys
Pandora
Nike Clearance
Nike Factory Store
New Nike Shoes 2019
Louboutin Outlet
Nike Cortez
Womens Nike Shoes
Nike Sneakers Sale
Cheap Nike
Yeezy
Red Bottom Heels
Yeezy Boost 750
Jordan 11 Blue
Nike Air Max 720
Sneakers Website
Yeezy Boost 350
Nike Air Max 95
Adidas Yeezy Shoes
Nike Lebron 16
Air Force 1
Yeezy Shoes
Nike Shoes
Air Force 1
Ferragamo Belt
Air Max 95
Nike Clearance
Pandora Canada
Red Bottom Shoes
Nike Presto Women
Fjallraven Kanken
Nike Outlet Store
Air Jordan Retro
Nike Air Zoom Pulse
Nike Air Max
Lebron 16
Red Bottoms
Pandora Canada
Red Bottom
Louboutin Heels
New Nike
Nike Outlet
Ferragamo Shoes
Air Max 98 Gundam
Christian Louboutin
Nike Free Run
Pandora Earrings
Ultra Boost
Nike Uptempo
Pandora Jewelry
Nike Shoes 2019
Lebron 17 Low
Yeezy Boost
New Nike Shoes
Pandora Bracelets
Pandora
Air Max 720
Nike Outlet Store
Pandora Ring
Nike Black Friday
Jordan 11 Retro
Nike Shoes For Kids
Adidas Yeezy
Louboutin shoes
Ferragamo
Mens Nike Shoes
Nike Cortez Men
Fjallraven Kanken
Jordan Retro 13
Louboutin Outlet
Asics
Kyrie Shoes
Nike Factory Store
Pandora Jewelry
Vans Shoes Outlet
Nike Huarache
Adidas NMD
Moncler UK
Air Jordans
Nike Factory Outlet
Nike Shoes
Nike Factory Store
Nike Free
Nike Outlet Store
Nike Factory
Jordan Retro
Lebron James Shoes
