Brontosaur wrote:Mark, your layout made it quicker, hats off !
Not quite.... I'm french !Icarus wrote:Brontosaur
Are you from Australia as well ?
if so where abouts are you ?
Nice find! If I had to guess at the missing part implication, I would say it's the -15v bias shift attached to the 3K3 resistor. This effectively drops the OPs schematic ground connection to ~ -5V. This drastically reduces the gain of the stage as well as increasing the current through the stage from .5mA to about .8mA. It also changes the clipping characteristics because of the bias q-point. If I guessed wrong then....carry onjoey wrote:I serendipitously found the source of this mod, and it is a lot less exotic then you guys think!!! It Actually comes from the Crunch channel of the Marshall 6100 30th Aniversary models! nearly Verbatum, except for one huge detail!
Wrong!Groovenut wrote:Nice find! If I had to guess at the missing part implication, I would say it's the -15v bias shift attached to the 3K3 resistor. This effectively drops the OPs schematic ground connection to ~ -5V. This drastically reduces the gain of the stage as well as increasing the current through the stage from .5mA to about .8mA. It also changes the clipping characteristics because of the bias q-point. If I guessed wrong then....carry onjoey wrote:I serendipitously found the source of this mod, and it is a lot less exotic then you guys think!!! It Actually comes from the Crunch channel of the Marshall 6100 30th Aniversary models! nearly Verbatum, except for one huge detail!
Back to studying for me I guess I cant elevate myself from newb just yet!joey wrote:Wrong!Groovenut wrote:Nice find! If I had to guess at the missing part implication, I would say it's the -15v bias shift attached to the 3K3 resistor. This effectively drops the OPs schematic ground connection to ~ -5V. This drastically reduces the gain of the stage as well as increasing the current through the stage from .5mA to about .8mA. It also changes the clipping characteristics because of the bias q-point. If I guessed wrong then....carry onjoey wrote:I serendipitously found the source of this mod, and it is a lot less exotic then you guys think!!! It Actually comes from the Crunch channel of the Marshall 6100 30th Aniversary models! nearly Verbatum, except for one huge detail!but very close!, you were in the right mind frame just missed a detail.
In all fairness you were technically right, it was the -15 that was wrong, but you would have to realize the effect of that amount of over biasing to question the schematic. You have come a long way in this past year thoughGroovenut wrote: Back to studying for me I guess I cant elevate myself from newb just yet!
Thanks Joey!joey wrote:In all fairness you were technically right, it was the -15 that was wrong, but you would have to realize the effect of that amount of over biasing to question the schematic. You have come a long way in this past year thoughGroovenut wrote: Back to studying for me I guess I cant elevate myself from newb just yet!
Seems there's a 22uF in parallel with 1K5 at V1B cathode ... Hmmmm ... I'll give it a try ...joey wrote:I serendipitously found the source of this mod, and it is a lot less exotic then you guys think!!! It Actually comes from the Crunch channel of the Marshall 6100 30th Anniversary models! nearly Verbatim, except for one huge detail!
6100?joey wrote:I serendipitously found the source of this mod, and it is a lot less exotic then you guys think!!! It Actually comes from the Crunch channel of the Marshall 6100 30th Aniversary models! nearly Verbatum, except for one huge detail!
V1b is only for the clean channel. the crunch channel which this mod was taken from only utilizes V2A/B, and V6A/B. The one huge detail is what Groovnut, and I have been discussing. The person who did the mod most likely didn't understand how it was really working in the 6100. If it by chance sounded good the wrong way, well then......Brontosaur wrote:Seems there's a 22uF in parallel with 1K5 at V1B cathode ... Hmmmm ... I'll give it a try ...joey wrote:I serendipitously found the source of this mod, and it is a lot less exotic then you guys think!!! It Actually comes from the Crunch channel of the Marshall 6100 30th Anniversary models! nearly Verbatim, except for one huge detail!
What better way is there to Mod a Marshall amp, than mod it using another Marshall circuit.demonufo wrote:
6100?Priceless.
Well spotted, Sherlock.
I'll have a closer look and try to get close to V2 &V6 values. Sounds more 'hifi' to me as it's now. And the pots values after V1 are far from the average marshall ones. I suppose that's for tailoring the clean channel. Thanks Joey !joey wrote:V1b is only for the clean channel. the crunch channel which this mod was taken from only utilizes V2A/B, and V6A/B. The one huge detail is what Groovnut, and I have been discussing. The person who did the mod most likely didn't understand how it was really working in the 6100. If it by chance sounded good the wrong way, well then......
