Diagram for 50/100 watt switch
novosibir
Post by novosibir » Fri Dec 09, 2005 7:46 am
And think about, that with only 2 tubes in use your B+ will rise up about 4-8 volts, because the load to your power supply is diminished! So better adjust the bias/plate dissipation only with 2 tubes in use.
Larry G
Brentsp
Post by Brentsp » Fri Dec 09, 2005 8:49 am
novosibir wrote:And think about, that with only 2 tubes in use your B+ will rise up about 4-8 volts, because the load to your power supply is diminished! So better adjust the bias/plate dissipation only with 2 tubes in use.
Larry G
Hmmm how off would the bias be? Theres lots of amp manufactures that have a half power switch and I don't think they have it wired to change the bias also.
novosibir
Post by novosibir » Fri Dec 09, 2005 8:55 am
Brentsp wrote:Hmmm how off would the bias be? Theres lots of amp manufactures that have a half power switch and I don't think they have it wired to change the bias also.
Most of the amp manufacturers are biasing their amps far too cold*, so switching 2 tubes off can't be a problem.
Larry G
(*) An exception has been the 1959HW. This amp was biased at nearly 100% plate dissipation (!)
Brentsp
Post by Brentsp » Fri Dec 09, 2005 9:04 am
I know Bogner has his amps biased correctly and his XTC has a half pwr switch but I don't know how its wired.
Billy Batz
Post by Billy Batz » Fri Dec 09, 2005 9:20 am
Just FYI Ive always pulled tubes form my amps without rebiasing or even without adjusting the impedance.
Bainzy
Post by Bainzy » Fri Dec 09, 2005 10:00 am
Yep the Jublilees had Pentode/Triode switches. I've tried both that switch and pulling the tubes, and the pent/tri switch is just so much more effective for curbing volume, not only does it make the amp a lot quieter on 10 it sounds better too in my opinion.
Shred Guitar
Brentsp
Post by Brentsp » Fri Dec 09, 2005 10:02 am
Bainzy wrote:Yep the Jublilees had Pentode/Triode switches. I've tried both that switch and pulling the tubes, and the pent/tri switch is just so much more effective for curbing volume, not only does it make the amp a lot quieter on 10 it sounds better too in my opinion.
I'm actually doing both with two seperate switches......... so it will lower it to around 30 watts.
Billy Batz
Post by Billy Batz » Fri Dec 09, 2005 10:09 am
If this is solely about cutting the volume lemme curb that myth right now. Brent take 2 tubes out and listen. The difference is not even a click ona hotplate. Its a hair. Its a little less balls mostly. Even a 50w isnt going to be much lower then a 100W. A click on the attenuator. I dotn know if combining it with a Pent/Tri and having them both on at the same time will help more with volume or just having a P/T is enough but just a 50/100 switch is a bit of a waste on its own IMO especially when you can just pull 2 tubes. Ive done it on all my amps. All my 100W amps anyway. Totally a marketing thing. People who know nothing about amps think its a great thing because they always think its half as loud. It doesnt work like taht. Power doesnt=dbs; dbs dont=percieved volume. Now if you were intending to sell your amps... :wink: ;)
Brentsp
Post by Brentsp » Fri Dec 09, 2005 10:11 am
Billy Batz wrote:If this is solely about cutting the volume lemme curb that myth right now. Brent take 2 tubes out and listen. The difference is not even a click ona hotplate. Its a hair. Its a little less balls mostly. Even a 50w isnt going to be much lower then a 100W. A click on the attenuator. I dotn know if combining it with a Pent/Tri and having them both on at the same time will help more with volume or just having a P/T is enough but just a 50/100 switch is a bit of a waste IMO especially when you can just pull 2 tubes. Totally a marketing thing. People who know nothing about amps think its a great thing because they always think its half as loud. It doesnt work like taht. Power doesnt=dbs; dbs dont=percieved volume. Now if you were intending to sell your amps then its useful ;)
I know what you saying but the face plates are already done and labled, no turning back now, I'm doing it. :wink:
Billy Batz
Post by Billy Batz » Fri Dec 09, 2005 10:16 am
I know. Its the prototype :D
Brentsp
Post by Brentsp » Fri Dec 09, 2005 10:24 am
Billy Batz wrote:I know. Its the prototype :D
The volume is only around 3dbs lower but the feel and head room changes quite a bit in 50 watt mode. Combine that with the tubes in triode mode and you have around 30 watts with a great soft feel, lowered headroom and volume. I did this with my XTC and Mark IV and it works great IMO. Unscrewing the back panel and pulling two tubes is fine but flicking a switch and halfing the impendence is lots easier.........at least I think so.
Billy Batz
Post by Billy Batz » Fri Dec 09, 2005 10:29 am
Different strokes. Its unusual for me to ahve the rear panels on my amps ever. I think its probably a little different for high gain amps that you dont crank all the way as well. Ive always cranked the channel switching amps I had too. There isnt an amp Ive owned that I couldnt get a good zeppelin live sound by diming the master and bringing thr gain up a bit.
Brentsp
Post by Brentsp » Fri Dec 09, 2005 10:33 am
Billy Batz wrote:Different strokes. Its unusual for me to ahve the rear panels on my amps ever. I think its probably a little different for high gain amps that you dont crank all the way as well. Ive always cranked the channel switching amps I had too.
With non master volume I would think the dual switches would be even more desired but maybe not. I always used the half pwr and tri/pen modes if the amp had them so I guess thats why I want it on my amp. Are you going to be around the PC or phone today. I may go home early and finish up my amp so I can have it for the OK Ampfest tomorrow.
Billy Batz
Post by Billy Batz » Fri Dec 09, 2005 10:35 am
Yeah. Im off today. Its a snow day. Actually I dont have snow days just days I dont feel like working which have been way too few and far between.
Brentsp
Post by Brentsp » Fri Dec 09, 2005 10:38 am
Billy Batz wrote:Yeah. Im off today. Its a snow day. Actually I dont have snow days just days I dont feel like working which have been way too few and far between.
ok super. I may call upon you if I run into a pinch because I have to have this done by tonight. The head cab supposed to come today to <crosses fingers>.
