Calculating RC time constants...and why you should.
- VelvetGeorge
- Site Owner
- Bainzy
so, how would I go about BOOSTING the mids in a circuit? (or cutting everything else to simulate that)
Shred Guitar
Shred Guitar
- VelvetGeorge
- Site Owner
- rjgtr
Raising the mid pot to 50k or 100k defionitely boosts the mids. But it also boosts the bass a bit too. I think youll find taht lowering the mid cap to .0022 really boosts the mids (and with mid boosts gain and harmonics as well) but no matter what you doo you shouyld probably go to a 56k slope resistor. Or even 100k. Your just decreasing gain by doing that especially in the low end and low mids which can get muddy when you do those things. I dont like doing either of them on a marshall because they really muddy up the low end.
Probably the best way to do it by far though is too increase your treble cap value. Switching between 2 different treble cap values is used as a mid boost control in many amps. It mostly boosts high mids but I really doubt youd want to boost low mids myself. I dont like it. I think youll find raising the treble cap value to 680p or .001 will give you a real mid boost. I especially like to do that on fenders but Ive meant to do it more with marshalls for a long time.
Boosting Mids
Put all of your tech tools away and go to your local pawn shop and buy a Peavey amp from the 80s. If that doesn't give you enough mid range, god help you!
- Bainzy
I don't actually have a treble cap right now, just a cap over the mixer resistor. What would change if I added one?
Shred Guitar
Shred Guitar
- Brentsp
Look for the wire thats going from the treb pot to a cap on the board. That wire should be connected to a 250pf, 470pf, or 500pf cap. Thats the treble cap Dan is referring to.Bainzy wrote:I don't actually have a treble cap right now, just a cap over the mixer resistor. What would change if I added one?
- Bainzy
Oops!
Sorry, you're right Dan I totally misread what you said, for some reason I got it into my head that you said bright cap. I changed the treble cap to a lower value before (500pf) but didn't like the way it sounded, so I think I'll leave it at 250pf.
But still, what are the effects of having no bright cap vs. having a bright cap?
Shred Guitar
Shred Guitar
- Bainzy
right, I guess there's no point in adding one then as the volume is always on 10
Shred Guitar
Shred Guitar
I don't think in the purest sense that this is correct. Adding "resistance" to a circuit doesn't effect frequency response...but...changing the impedance does effect frequency response...as George said. Resistance is a DC characteristic while Impedance is an AC characteristic. Not trying to nit pick, but you do have to be careful with your terminology.rjgtr wrote:Resistors resist power flowing. The smaller the power the less you get. So high frequencies, which take less power to generate are easier to block. Obviously the effect is more subtle than using caps.
BD
Dan,
I wanted to add something to your "series resistance" discussion that you probably already know, but some may find helpful. If you place a resistor in series right before the input grid of a tube you will notice some treble attenuation as well, due to the internal capacitance of the tube (which is quite small). This also form a low pass filter, and is a technique commonly used to supress oscilations and stability issues.
erigm
