Replace Impedance Selector JCM 800 Valve Amp
Wriggle
Post by Wriggle » Sat Jul 25, 2015 1:24 pm
Hi
I wonder if someone could help me with the wiring of a replacement Impedance selector.
I can handle a soldering iron and have carried out some fairly complex mods on my valve amps using graphic directions though I am NOT an electronic engineer and cannot even read a schematic diagram.
I have attached a photo of the old selector (still wired) and the brand new replacement.
The new one has terminals 1-6 plus the earth in the centre.
Could someone please just tell me which colour cable (green, purple, yellow & black) goes to which of the 1-6 terminals and if I need to add a jumper cable from earth to one of the numbered lugs (with the black cable)
The old selector does not have any numbers on the terminals...
Marshall Ohm Selector 1 copy.jpg (240.13 KiB) Viewed 1144 times
SDM
Re: Replace Impedance Selector JCM 800 Valve Amp
Post by SDM » Sun Jul 26, 2015 4:38 am
100 watt wiring would be:
Black wire (the one headed to speaker terminals) = "P" (center terminal)
Other black and the purple wire (should already be together on the original switch) go to 4 ohm/terminal 1
Yellow to 8 ohm/terminal 2
Green to 16 ohm/terminal 3
That's it, done. No jumpers, no earthing here.
danosol
Post by danosol » Sat Jun 07, 2025 7:03 pm
There is also a black wire going from the board to the original impedance selector. Where does it go on the new selector?
Ajay
RIP Ben I will miss you.
danosol
Post by danosol » Sat Jun 07, 2025 7:09 pm
The one in question goes from the DI to the selector which is jumpered to the 8 ohm by a resistor.
Ajay
