Hi guys,
Need help for restoring this beauty
Power trans. is not the original one, cap board looks not good and phase invertor can cap is not wired, you will see 3 extra caps on bias circuit and also it has a additional cap wired on the main board near the 32 uf dual cap.This amp looks good but with your help it will be pretty nice again
My idea is, split cathode for one side an add some other things on the 67-68 circuits and I'll leave the other side untouched.
Since its a super Pa which I dont have any opinions about 2 days before
but it looks similar to 100 watt superleads.I have checked the layouts pre, power amp and cap board wiring is same with brige rectifier.I've decided to use Metro Amp Drake 1203-80 transformer for replacement.Is that ok ?
There is nothing on output trans, what is it Drake 2" or Dagnall ?
Anyway these are the pictures
Minimass looks really tiny in here
Mustards look so nice
No bias pot on it and yellow dudes are 47 uf 350V caps
It's serial number is SP/20527
deliturko
