Just for your info anytime you want to increase the gain specially in a super lead type amp will increase your chances of getting PO, and sometimes the only cure is to reduce the gain a lot
Let's hope we find a cure for yours.....
I found some more tricks BTW but they are more complicated to do...
heres one that may work.....(still easy..)
Increase your cathode resistor a little at V1 (I guess you have the stock 820ohms so try a 1.1k there first then a 1.5k there...), that will rebias the V1 with a hair less gain and it might be just what you need, I think your problem comes from the pre amp section, you will regain more dirt when cranking the amp from the output section
a more complicated one would be to displace your output tranny to an other location on the chassis, turn it around, mouve it an inch away till you find the best spot that reduce the squealling....note: the output must be as far as possible from the input jack....
