How Do Make My '68 super lead split cathode??
Guest
Post by Guest » Thu Oct 27, 2005 12:34 pm
Anyone know how to make my '68 Super Lead split cathode??
Bainzy
Post by Bainzy » Thu Oct 27, 2005 12:45 pm
I wouldn't really recommend modding an amp like that, but if you must, make sure you do it so the mod is 100% reversible - no holes drilled etc.
To make it split cathode, I'd find an amp diagram on the metroamp site for a 68 or 69 with split cathode, and try and copy that, it's a lot easier than following an explanation.
Shred Guitar
Post by Flames1950 » Thu Oct 27, 2005 3:31 pm
Gulp....please don't do this.....plenty of split cathode Leads out there if it's what you're after....or a nice Metro '69 kit.......
Billy Batz
Post by Billy Batz » Thu Oct 27, 2005 7:58 pm
Besides, that one thing wont make a very large difference at all. Its one of many things that makes a difference together. If you think your amps all the sudden gonna get a lot more cut and tightness it won. I have that on a switch in one of my clones and it only makes a subtle difference on its own.
Im curious what made you want to go that route?
Bainzy
Post by Bainzy » Fri Oct 28, 2005 9:25 am
Yeh I expected a large (well, reasonably noticeable) difference by switching cathodes at V2 on my amp from:
820ohm / 820ohm + .68uF / 820ohm + 330uF
yet the difference is not really that noticeable. As I expected, the 820ohm has less gain and is clearer, the .68uF boosts the mids ever so slightly, and the 330uF sounds a bit thicker. Maybe it's just because I've got different speakers and I'm using a PPIMV and pentode/triode switch, but with the Ralle spec I've got a closer EVH sound with the .68uF than the 330uF.
Shred Guitar
Billy Batz
Post by Billy Batz » Fri Oct 28, 2005 10:58 am
Sometimes we say this makes a huge difference or that but we're speaking relatively. In the grand scheme of things a slight cathode value change wont make a huge difference. it can but not there.
Bainzy
Post by Bainzy » Fri Oct 28, 2005 11:17 am
Would the difference be more noticeable with or without more power amp distortion? (or same throughout)
Shred Guitar
Billy Batz
Post by Billy Batz » Fri Oct 28, 2005 11:23 am
Hmmm.... I think you need to be at leats a bit cranked to get the most effect but I dont know if Id say 10 is more noticaable then 6. Maybe
