El34, 6550 pin schemes, are they the same?
Guest
Post by Guest » Sun Jul 24, 2005 8:20 pm
I've got a superlead that was outfitted with 6550 tubes. I want to switch it to el34s. Are the pin schemes for the two types of tubes the same. Does anybody have a link to a website that has detailed information on pin identity for different vacuum tubes? Thanks.
rjgtr
Post by rjgtr » Sun Jul 24, 2005 8:32 pm
EL34s require one more pin than a 6550 or 6L6, fortunately Marshalls are all wired to be compatible with EL34s. The only change that is needed is a change to the Bias circuit. I'm sure there's a post here on how to do this.
Richard Johnson
Playing an instrument doesn't make you a Musician ... Listening does...
Post by Flames1950 » Mon Jul 25, 2005 12:15 pm
Usually you end up adding a resistor in parallel to the current bias resistor. The bias resistor is inline with the bias adjustment pot, start by adding a resistor of the same value over the top of the original to halve that resistance value, and see if it ends up with about the right range.
jerryd
voodoo
Post by jerryd » Mon Aug 01, 2005 5:19 pm
voodoo tech head section has an easy to read one
