Is Jimi's White 68' Strat Poly Or Nitro Finish?
Brandon
Post by Brandon » Fri Oct 01, 2010 5:42 pm
Anyone have any info?
It looks more nitro than poly to me, especially because of the wear on it and because the poly olympic white guitars I've seen have all turned completely yellow over the years and the finish on the body and neck remains almost like new... but when fender custom shop started reproducing the white strat a few years ago, I believe they finished it in poly.
Here's a photo:
http://media.photobucket.com/image/wood ... -strat.jpg" onclick="window.open(this.href);return false;
Ydna
Re: Is Jimi's White 68' Strat Poly Or Nitro Finish?
Post by Ydna » Fri Oct 01, 2010 8:44 pm
Beautiful guitar. I saw it in person in Seattle, among others. Looking at the picture, I think it has faded, because Olympic white is a bleach white. In the picture it is faded a bit. I think you're right on it being Nitro though, but after Jimi's death, it has probably been stowed away somewhere, except for going to museum's, and the museums don't allow flash photography, and the museum I saw it at (EMP) the area was very dim.
~Current Amps~
1. 1963 Sano Supersonic
2. 1990s Fender Dual Showman
3.JTM45/100 Build
~Future Amps~
1. 69 Superlead
2. Lots of Metropoulos amps
Brandon
Post by Brandon » Sat Oct 02, 2010 4:21 am
Yeah I just can't imagine those scratches on the left bottom corner (probably from jimi's rings from pick strokes?) existing on a poly finish. It would def make more sense if it was nitro.
Ydna
Post by Ydna » Sat Oct 02, 2010 10:08 am
Idk what else it could be. Dings and scratches just kind of happen on guitars. Coulde be picking, who knows? I still think you're right on the Nitro finish.
~Current Amps~
3.JTM45/100 Build
~Future Amps~
1. 69 Superlead
Xplorer
Post by Xplorer » Tue Oct 05, 2010 7:38 pm
i think, that poly remains the same over the years, i mean, cellulosic finish goes yeallow much faster. But this guitar was bought in 1968, jimi used it less than two years. and we can suppose that this guitar wasn't exposed to uv light after that. This would be the reason why it stayed white, a lot. but cellulosic goes very yellow with uv, and disipate with alcohol, acid ... beer, sweat ...poly is more resistant. i've seen this guitar too at the emp. by the way : veeeeeeery small room relative to jimi, into a huge museum. but it's nice to have other jimi's equipments over the world, and not only there.
(452.44 KiB) Downloaded 2190 times
(459.63 KiB) Downloaded 2190 times
(452.08 KiB) Downloaded 2190 times
Xplorer
Post by Xplorer » Tue Oct 05, 2010 7:39 pm
some more
(468.86 KiB) Downloaded 2190 times
Brandon
Post by Brandon » Tue Oct 05, 2010 8:03 pm
Very nice pics! :wink:
Yeah it's really shiny which says poly to me (but that could just be good caretaking on a million dollar gitter)... but then it has slight aging coloration and has only been used for aprox 2 years which says nitro... and those scratches at the bottom left, I don't see it being possible to make those kind of scratches and break the surface layer that cleanly and deeply on a poly body just from a big swinging pickstroke with a ring on your finger.
He would have had to slammed right there with hammer force! But the angle of the cutaway, the strength of poly and the physics of hitting the cutaway corn at that angle... to me it must be Nitro.
I indeed have tried to make those scratches on a poly body mythbusters status while playing :mrgreen: , and it just doesn't seem to be possible to me on a poly finish.
parkhead
Post by parkhead » Tue Oct 05, 2010 11:42 pm
Nitro color over poly till 73 - 74
the guitars were clear coated in poly then color shot in nitro
sunburst stayed with nitro over poly longer
when you look at late 60's to mid 70's guitars the nitro wears through to the poly clear coat
P
Freedom
Post by Freedom » Wed Oct 06, 2010 3:16 am
Probably not much help but what the heck...
"1968 Stratocaster specs:
* Black Fender peghead decal with 2 patent numbers (2,741,146 & 3,143,028).
* "F" style tuning gears replaces "Kluson-Deluxe" gears.
* Polyester thick finish replaces nitrocellulose lacquer. This transition is slow, and often a 1968 Strat can have a poly finished body with a lacquer neck.
* Fender peghead decal is now under the finish, instead of on top. Because of this, the face only of the peghead stays lacquer, even though the rest of the neck is polyester (was done this way because the poly finish reacted with the decal). This can really be seen on well-used Strats, because the poly finish does not yellow, where the lacquer peghead finish does. Hence the face of the peghead can be a yellowish-brown, and the rest of the neck is not. Also the face of the peghead can finish-check, where the rest of the poly neck generally will not.
* Under the pickguard wiring transitions from cloth-covered wire to plastic (PVC) covered wiring. "
Source: http://home.provide.net/~cfh/fender2.html" onclick="window.open(this.href);return false;
Freedom of Music <=> Music of Freedom
Post by Roe » Wed Oct 06, 2010 3:28 am
parkhead wrote:Nitro color over poly till 73 - 74
P
yeah, thats what I've been told as well
Tone seaker
Post by Tone seaker » Wed Oct 06, 2010 10:03 am
so that just destroys the theory that nitro sounds the best.
Xplorer
Post by Xplorer » Wed Oct 06, 2010 11:08 am
or, it destroys the theory that would say that poly doesn't sound so good.
to me, acrylic is the best for a body. at least for a natural telecaster body, and the most beautiful in this case. i 'm joining a picture of mine
(482.84 KiB) Downloaded 2157 times
(371.11 KiB) Downloaded 2157 times
Brandon
Post by Brandon » Wed Oct 06, 2010 1:02 pm
P
Are you saying the body was "sealed" with poly and then nitro color and then nitro clear coat?
And are we talking about polyester resin or polyurethane
Brandon
Post by Brandon » Sat Oct 16, 2010 12:28 am
Alright check it out, new photographic evidence from Woodstock :thumbsup:
Now I'm 99% certain it was a nitro finish. Check out that wear, that type of wear is just not possible on poly.
(657.67 KiB) Downloaded 2113 times
(639.16 KiB) Downloaded 2113 times
(504.57 KiB) Downloaded 2113 times
Brandon
Post by Brandon » Sat Oct 16, 2010 9:05 pm
more pics
(578.54 KiB) Downloaded 2093 times
(627.21 KiB) Downloaded 2093 times
(572.75 KiB) Downloaded 2093 times
