Bias Circuit
rip
Bias Circuit
Post by rip » Sat Apr 22, 2017 12:54 pm
Hopefully, this is an easy question...
Regarding the bias circuit of a JTM45/100...can someone confirm that:
-The bias splitter resistors are 220K
-The bias supply dropping resistor is 150K
-The bias pot is 25K linear
-The bias resistor in line with the bias pot is 47K
The reason why I ask is because I've seen other values here and there, in particular with the bias resistor and pot...so wanted to see if someone can confirm.
Rip
Re: Bias Circuit
Post by Roe » Sun Apr 23, 2017 8:00 am
the 47k and 150k varies slightly. The important thing to remember is to bias the tubes correctly
rip
Re: Bias Circuit
Post by rip » Wed May 03, 2017 1:34 pm
Thank you
Seems like I'll try the nominal valves...I'll be back if I need to tweak it
Rip
