Problems with my build.
Posted: Thu Sep 29, 2011 5:57 pm
So for a while now, everytime I would hit a note, or a chord, it would start crackling and popping, and wouldn't stop after I had stopped playing, this had happened once before, but it was just a weak solder joint that had come loose, so I had fixed it. This crackling noise only occured when the amp was on higher then two.
Then it came back again, checked that solder joint, it was intact.
So today, I decided to really investigate it. I warmed up the amp, plugged it in, same results. Then I put pressure on the top of the chassis near the inputs with my hand, and the crackling noise started up.
Almost any motion of the chassis resulted in the loud, crackling noise.
I took out the main board, and the wire that goes from the diodes on the rectifier board, to the 150k resistor on the main board, was barely soldered in. I'm not sure if that could have been it or not. I imagine it wasn't, because that wire has never been touched since I finished the amp.
With the Ceriatone chassis, and using BrianH's boards, the rectifier board hangs a bit over the power tube sockets. I took it out, and I noticed that on the 1k5 resistors, on the inner two tube sockets, the covering of the resistors had somehow come off in spots. Revealing some metal.
I've checked all solder joints, they are all solid, and don't have anything they could be coming into contact with. I don't have access to a camera right now, but I'll see what I can do.
I believe that the rectifier board chaffed off some of the covering. Could this cause that crackling noise?
