This is basically identical to the 100W kit instructions.
I like to use a nut driver to tighten the small nuts to the #6 bolts instead of using a flathead screwdriver to screw the bolts into the nut because its easier and you wont strip the bolts.
Step 4 - Installing the tube Sockets
- gutpile
For the ground lugs that need to be installed on the Power Tube sockets, I bend them with my thumb while holding them with pliers beforehand as shown in the photos below...
- (138.34 KiB) Downloaded 1005 times
- (154.57 KiB) Downloaded 1005 times
Metro Clips
- gutpile
Here is a pic of the installed sockets...
- (41.91 KiB) Downloaded 972 times
Metro Clips
