frenchie
Post
by frenchie » Tue Mar 04, 2008 7:18 am
i read somewhere that sozo's if they were not polarized nevertheless had an orientation.....does someone can say to me if i'm not wrong with the loading of my board with sozo's caps ...????
gtomax
Post
by gtomax » Tue Mar 04, 2008 3:00 pm
Not super critical, but banded end toward the tubes is the sentiment.
frenchie
Post
by frenchie » Thu Mar 06, 2008 1:21 am
sounds like my first mistake !! i feared it , and desoldering will be hard ( tree ends in a split turret ...ouch ! )...i saw some guys who have their amps soldered this way so i will try to run my amp like this
gtomax
Post
by gtomax » Thu Mar 06, 2008 10:37 am
You shouldn't really notice a difference
Herec
Post
by Herec » Thu Mar 06, 2008 3:12 pm
Actually alot of people prefer them to not be aligned, and even think they sound better. That's how it was done back in the day.
So no mistake at all really!
frenchie
Post
by frenchie » Sun Mar 09, 2008 6:32 am
ok ..so that's cool....i also have done one thing ...i've made the underboard wiring with pink cable ...might not be an error i think cause it's rated at 600v ...might fit well in the pream section..even better than the black wire no?
frenchie
Post
by frenchie » Sun Mar 09, 2008 11:13 am
ok ..i received my TAD 33uf 500V ...
frenchie
Post
by frenchie » Sun Mar 09, 2008 11:19 am
and a solen 0.0047uf rated at 1000V
now i will be able to load my power board ...at last !
frenchie
Post
by frenchie » Mon Mar 24, 2008 12:28 pm
frenchie
Post
by frenchie » Wed Mar 26, 2008 8:13 pm
little question now ....my chassis has the chance to be custom drilled ..in fact i didn't have already drilled the ot socket ....i also heard that in the 45/100 the original placement of the ot , bobbins of the pt and the ot in parallel , induced hum in the sound chain ....can i change a little the placement of the ot to make it dead silent when in standby mode ??? can someone give a simple drawing of the upper chassis with the most accurate placement of the ot ....i'm guessing it must be pretty similar to a sl ( the end bell covers in parallel with the front panel ) , perhaps i'm wrong ...someone can tell ??????
i would be very very interested
chubs
Post
by chubs » Thu Mar 27, 2008 8:35 am
Usualy best practice is to have the OT bobins turned 90 degrees from the PT. So yes the PT faceing front to back on the chassis and the OT left to right.
frenchie
Post
by frenchie » Thu Mar 27, 2008 10:46 am
in order not to have magnetic fields feeding themselves .....that's what i thought ...thanks
frenchie
Post
by frenchie » Tue Apr 01, 2008 8:27 am
a little quartet of 11th gens that look quite good :
frenchie
Post
by frenchie » Tue Apr 01, 2008 12:29 pm
ok so the polishing job is finished ...cannot got any further without a buffer wheel .....my last sand paper was the 2000 ....that's the best i can do see it :
myfoot
Post
by myfoot » Tue Apr 01, 2008 12:53 pm
Looks good!Can't wait to see it finished up !
