That will be a great build, by 'relic' I guess you mean taking a pair of rusty pliers to the power board?neikeel wrote:'s ok as I try to buy all the right angle ones that I see - the straight ones are no good live![]()
BTW - really nice work. I have a similar project in kit form with one of Robert 7026 panels, Marstran chassis and trannies just waiting for time, I have all the NOS stuff (inc the RS 32uF caps and the Dickinson spec replaced caps and resistor types - how sad is that?). Can't decide whether to relic the chassis and cap board too!
I made some progress today, started working on the boards. The paxolin I got from England is a lighter brown and more shiny than the stuff that Brian used for his boards. Really glad I have one of his as a reference for measuring as well as a high standard!
Printed a grid with 3/8" centers and very thin lines on paper as a drilling template, circled the holes to be drilled with a #38 drill bit, since I'm doing a solid pre board (the power board will be perfed):
After cutting and sanding the edges:
Commence drilling!
Made my own turret press, drilled an 1/8" hole in the end of a 1/4" steel stud and mounted it onto a 1/4" plate of aluminum so it could be clamped to a drill press. Then I ground one end of a 1/4" stainless steel stud to a point at about a 45* angle:
Commence pressing!
And inside the chassis for a test fit:
Tomorrow the power board!
