Great idea yngwie308, allow me to post here first
Yngwie at Randy Rhodes tribute:
http://youtube.com/watch?v=T1dPdfTeWIY
http://youtube.com/watch?v=1lNdZiJ0qak
http://www.youtube.com/watch?v=n1j6ZxSz8kI
http://www.alloutguitar.com/interview/e ... _malmsteen
Chronology of YJM US models;
The American Fender YJM Strat model year updates are as follows:
1988 Introduction: Along with the Fender Eric Clapton Signature Stratocaster, the Fender Yngwie Malmsteen Signature is the first or Fender's Artist / Signature series of guitars. Malmsteen and Clapton are the first Artists to be so honored. These early YJM Strats featured a modern (small) headstock, 21 Fender "vintage" medium frets, American Standard style 2-point pivot Tremolo, modern Fender/Schaller tuners, and 2 x Dimarzio HS-3 pickups (neck and bridge) and Fender single coil in the middle. Also, I believe the truss rod adjustment was via screw driver at the end of neck near top of pickguard. This model continues unchanged through 1993.
1994 1st update: Fender changes headstock to Yngwie's preferred late sixties large headstock, changes American Standard type tremolo to original, vintage Synchronized Tremolo, and aged plastic parts. Pickups were still 2 x HS-3 and 1 x Fender American standard (middle). This model continues unchanged through 1997.
1998 2nd update: Dunlop super Jumbo 6000 frets introduced. Tuners changed to Vintage Fender "F-Key" style. Dimarzio YJM pickup introduced, and is featured in the neck and middle position, with a Dimarzio HS-3 in the bridge. Mint pickguard with aged plastic parts. Truss rod access moved to headtock via allen wrench. This model continues unchanged through 2006.
2007 3rd and latest update: Bullet style truss rod is introduced. Deeper neck scalloping is introduced. Fender's standard wood screw Neck / body joint is finally changed to reflect Yngwie's special modification==>4-point machine bolt / threaded insert type neck anchoring system. Special, slimmer "C" shape neck profile is introduced. Pickguard changed to 3-ply white.
Some are claiming the 2007 YJM's have thinner neck profiles:
I caliper measured both my 2002 and 2007 YJM strats at the 1st and 12th frets.
The 2002 measures around 19.6 and 21.8 mm thick
With 2mm deep scallops
The 2007 measures 18.0 and 20.5 mm thick
With 2.3mm deep scallops
An Ibanez Wizard is spec at 17mm and 20 mm
So you can see the 2002 would have around 17.6 mm of solid wood around the lowest region 1st fret area and the 2007 would have around 15.7 mm of wood in that same region.
That is about 11% thinner where the neck is thinnest (low valley of a scallop)
That's a fair amount.
Also questioning his use of the YJM DiMarzio's:
I have this question in my head lately after closely examining a few pictures and videos of Yngwie with his guitars.
One can easily distinguish a DiMarzio YJM from a HS-3 from their magnet stagger at the B string. With the YJM, the magnet is even lower than the plastic cover, with the HS-3 the magnet is clearly raised above the cover.
I've seen closeup pics of his 2007 tours where Yngwie's even using his '07 updated artist series YJM Strats and even in those the neck magnet appears to be a plain HS-3 (visible from the raised B-string magnet).
In his concerto suite DVD with the Japanese philharmonic orchestra at some closeups one can clearly see the raised B-string magnet at the neck position which to me indicates that he's using an HS-3 there aswell.
It appears that most of his guitars use HS-3's in bridge and neck position.
Maybe it's really like the DiMarzio website says and he's only using the YJM pickup in some of his vintage Strats...
Btw, sometimes I really wonder if he's using those HS-3's and YJM's at all or if DiMarzio just say he does when he's maybe using something else/secret. (a purely speculative thought on my behalf, of course).
These aren't my quotes, thanks to YJM forum for data.
