Inspirational tones.
Joshabr1
Post
by Joshabr1 » Fri Feb 27, 2015 9:34 am
Damn this place must be in trouble. An amp like this and not a single post?? What are u guys waiting on. Eddie van halen!?
Post
by neikeel » Fri Feb 27, 2015 9:53 am
More traffic in the Marshall section - I rarely look here so maybe same for others. Gut shots would be nice too
Strat78
Post
by Strat78 » Fri Feb 27, 2015 10:09 am
These are great pics, do you have shots of the front and back panels plus the head cab? Is this your amp, if so what is the story? Most likely some classic tunes were recorded with this head! Yep, this should be in the Marshall section.
Joshabr1
Post
by Joshabr1 » Fri Feb 27, 2015 1:58 pm
Neil have you seen tht particular type output transformer before?? Is it an early heyboer??
pleximaster
Post
by pleximaster » Fri Feb 27, 2015 2:39 pm
Don´t think its a heyboer...
Chris ****** thought it might be a Drake HIFI transformer from early 70´s. Ops I just forgot to send him the dimensions to him...
plexi
Post
by neikeel » Fri Feb 27, 2015 4:00 pm
Joshabr1 wrote:Neil have you seen tht particular type output transformer before?? Is it an early heyboer??
No afraid not. Mr ****** much more likely to know! The PT looks to be a later Dagnall (standup type) but with random end bell with selector on it.
Joshabr1
Post
by Joshabr1 » Sat Feb 28, 2015 10:02 am
That's exactly what I thought about the mains as well. PlexiM told me different. Maybe he will elaborate here.
pleximaster
Post
by pleximaster » Sat Feb 28, 2015 1:12 pm
i am probably wrong won´t argue with neikeel...
i can see now how a stand up can be mounted laydown...
best plexi
pleximaster
Post
by pleximaster » Sat Feb 28, 2015 1:13 pm
best plexi
Post
by neikeel » Sat Feb 28, 2015 2:02 pm
pleximaster wrote:i am probably wrong won´t argue with neikeel...
best plexi
Oh I would look at anything I say critically and pull me up if I am wrong, that is how I keep on learning.
That era of amps (late 67/early 68) were double drilled. I have had two in the 104** range that were obviously punched for the then current 1202-132 (2" stack) and then hand-drilled for the Dagnall C1998 (1 1/2" stack) unless of course I had tow that blew their Drake transformers and had them replaced with a Dagnall. Neither had their original PT but I put Dagnall T2562 types in both to match their Dagnall OTs and C1999 chokes. I have seen amps in the SL/10 series with lower numbers and Dagnalls too.
