Hi,
Here's a clip I just made using Holy (my customised 335-like) and the '68 clone I've been tweaking this week.
http://soundcloud.com/billbokey/holy-cl ... 9-cab-g12m" onclick="window.open(this.href);return false;
The cab is an early 69 slant loaded with G12M Lead (T1121 w/ 102 003)
Valves are :
V1 : Mullard I63
V2 : Brimar CV4004
V3 : Mulalrd M8137
V4-7 : Valve Art EL34B
Amp settings : volume 8, treble & presence 5, bass & mid 10
The amp is attenuated with an Airwreck clone on -5dB so it doesn't blow the speakers !
It has all NOS caps : Mustard , Lemco, silver mica & Dogbone. NOS Allen Bradley & Neohms Carbon Comp resistors, Piher and Iskra Carbon Film resistor. Marstran Trannies.
Erie 32/32 preamp cap, Rifa Mains (50µf) & Screens (16µf), F&T PI (32µf)
Guitar is a Custom77 Needle & Pins : http://custom77.com/html/Needles__Pins-66-prd.html" onclick="window.open(this.href);return false;
Upgrade from stock :
- Pickups : Classic77 bridge + P77-HB neck (see http://www.custom77.com" onclick="window.open(this.href);return false; for more info)
- CTS 550k pots
- PIO tone caps
- Gotoh Tune O Matic
- Switchcraft switch.
D'addario 10-46 strings, nothing fancy.
The volume is on 7.5 on the bridge pickup, then on full for the neck pick up then down to 3 or 4 I can't rememeber before going back to the brdige pickup, still on 7.5.
'70 Superlead vs 12xxx clone + '69 cab
- bill bokey
- bill bokey
Re: Holy (335-like) and '68 Supelread clone + '69 cab
And here's the same setup but the amp is my '70 Superlead ('68 specs) :
http://soundcloud.com/billbokey/holy-su ... 9-cab-g12m" onclick="window.open(this.href);return false;
Same preamp valves. Like the first clip it's recorded with an M160 and an MD21 on the same speaker, equal volume. I did not change the gain on the soundcard (FF800) between the 2 recordings so if you hear a difference ...
- bill bokey
Re: '70 Superlead vs 12xxx clone + '69 cab
The '70 Superlead is up for sale, if anyone is interested. At the moment I have too many amps and not enough cash, unfortunately.
