My JTM50 lacks balls compared to the originals so I took it out of it's case tonight and took some measurements. Made a few interesting discoveries......
Pots
Volume 1 - 960K
Volume 2 - 960K
Treble - 260K
Middle - 26.4K
Bass - 933K
Presence - 4.19K
As the presence pot only measures 4.19k I won't have as much NFB as I should. Its not much but can still make a difference. More NFB would bring the bass down a tad whilst letting the highs through still.
I also have a PPIMV installed but I may remove it as I wonder if it changes the tone even when its turned all the way up. I never use it as it sounds terrible in an amp that relies on a lot of NFB!
So I'm thinking, remove the PPIMV and maybe replace the Volume and Presence pots? Also may change the tonestack capacitor from 250pf to 270pf.
Thoughts?
JTM50 Tweaks
Re: JTM50 Tweaks
I typically change V1 electrolytic to 10uF or less.
270pF is a value I have used and it works fine - not sure if there is much difference vs 250pF.
I quite like 27k NFB on the 16 ohm tap (i.e. stock values).
The secret on this is your settings.
Plug into high input channel 1 (I use 100pF tubular ceramic on the pot) don't jumper.
Volume 1 on 8 (unused vol 2 on 4)
Bass 0-2
Middle 10
Treble 8-10
Presence 6-8
Decent 4x12 and you are away.
Give the amp some time. In a circuit like this I have found the OT is very important and I have used the Marstran -139 and -128 (even more bass!!) to good effect. I built one with a cheaper OT I had lying around and it was awful, IMO. The B+ should be around 420v with that sort of voltage on the output plates. Only use 50uF mains filtering, 32PI, 16 screens and 32/32 preamp.
Bass 0-2
Middle 10
Treble 8-10
Presence 6-8
Re: JTM50 Tweaks
I want to stick to stock values if I can as I know the stock values work well in other amps I've listened to. Plus its more of a challenge fine tuning then
The settings I currently use are:
Volume 1 on 10 (unused vol 2 on 0)
Bass 0
Middle 10
Treble 8
Presence 10
I'm using a Classictone OT at the moment (40-18025). Have you ever used them?
I may move the NFB over to the 16Ohm tap, first though I'm going to see if I can get hold of a 5K pot that reads 5K or over. I did some calculations and as my pot reads 4.2K it will lower the NFB a bit and also if you think about it the presence cap won't be as effective. Same effect going from 270K to 470K
I'm removing the PPIMV as well just in case that is affecting it somehow. I never use it anyway.
Bass 0
Middle 10
Treble 8
Presence 10
Re: JTM50 Tweaks
5K Presence Pot is fine, when I took it out of the circuit it measured 4.9K which is close enough. The new one I bought is 5.1K so there isn't much point swapping them.
I removed the PPIMV and now the amp seems to sound better. I played it through my PC the other night (Load Box, Line Out, Focusrite, Virtual Cab Software) and it sounded good. Played it tonight through a real cab and it sounds much better. Maybe the PPIMV was killing the sound somehow?
I am tempted to try the 16Ohm Tap for the NFB. What I may do one night is put a resistor in parallel with the 27K to bring it down to 18K (same as 27K on the 16Ohm tap). I still have to keep the bass on 0 but I reckon that with the extra NFB I could probably turn the bass up or even jump the channels.
