For this mod i use like referring soldano slo schematic which use optocoupler vtl5c1 to switch master and channel. I think also to change way for clean channel. I thind to make in this way:
OD channel v1a --treble peak--gain pot(1M audio) --v1b
Clean channal v1a--treble peak/voltage divider--gain pot(500k audio)--v1b
My mind is this, the clean tone of od channel( gain about 2 3 ) is more beautiful than clean with v1b bypassed, so i think to use the same configuration but for clean channel use a voltage divider(470k/470k) and gain pot of 500k, in this way i should reduce gain about 50% and have a good clean channel. For switch clean od channel I thing to do like master volume of soldano slo, while for master volume and power suppy i will use the same of soldano slo.
What to you thing about this way for clean channel? Are in this way the two channel completly indipendent?
This is schematich of my idea and the schematic of soldano slo
http://www.slocloneforums.com/download/file.php?id=1339
