Thanks a lot for the input here men.
So, just an update, I did remove the treble peaking circuit with the 470k over the 470pf and I didn't like it. The tone became dull and didnt quite resemble the highs that really make this thing sound like a Marshall. So back in it went and instantly the tone was much better.
Curious as to why you see a lot of people (who should probably know better) suggesting the removal of this circuit to attenuate highs. It does remove highs but not in any good way.
That being said I did remove the treble peaker tied to the preamp pot. My gain control is usually up all the way and I didnt hear any adverse effects with the guitar's vol. control down as I run a tapped humbucker for single coil-ish cleans. Still plenty of clarity.
Next, realizing that the amp had been converted to 6550's I looked at the NFB wire. It was still connected to the 4 Ohm tap. I quickly moved it over to the 8 Ohm tap for a little less NFB and WOW, what a difference! I certainly wasn't expecting such a significant change as I had experimented with this before on EL-34 loaded amps but always found 4 Ohm to sound best for that particular tube..
This was my first experience with a 6550 loaded 70's Marshall. Seems the 6550's really do benefit from less NFB as the highs were now much more pleasant and smoother sounding. I would say it just about solved the harshness issue I was having.
During this experimenting process I got a little crazy and damaged one of the green .022 PI coupling caps.. Ooooops. Guess they are quite fragile indeed.
Its the cap that's coming off of the grid of V3a to the wiper of the Master volume pot.
Can any of you suggest a suitable cap for replacement? I was looking at the Sozo mustards as people claim to hear a noticable difference in warmer highs in Marshall's with these caps.
While I'm ordering, what would be an improvement for these .027uf caps or in general?
Might change out V1a's 10K cathode resistor with the 8.2k as Demonufo suggested. Carbon comp or Carbon film?
Once again, thanks for sharing your knowledge and opinions with me, I really do appreciate the input!
