vkaxeman
Post
by vkaxeman » Sat Mar 01, 2008 12:11 am
vkaxeman wrote:Sweeet Dude!!!!!! Thanks for the DVerb Screenshot!!!!
MM7h choke ordered!
MM7h choke received today. MP3's and Pics tomorrow!
My first project: 1959HW to 12xxx Courtesy of the Late Great Rockstah a.k.a. Edward Van Abrahamian
bluze81
Post
by bluze81 » Sun Mar 02, 2008 4:04 pm
Just curious if anybody has tried a 3h choke in a 100w build? might really ghost, but they sound great in 45s and 50watter amps, really open and aggressive, IMHO,
thousandshirts
Post
by thousandshirts » Sun Mar 02, 2008 4:35 pm
bluze81 wrote:Just curious if anybody has tried a 3h choke in a 100w build? might really ghost, but they sound great in 45s and 50watter amps, really open and aggressive, IMHO,
Hi Bluze!
The MAR100C that VK just had in was 3H.
Hard to keep up with the Jetsons here, so many changes!
bluze81
Post
by bluze81 » Sun Mar 02, 2008 8:08 pm
thousandshirts wrote:bluze81 wrote:Just curious if anybody has tried a 3h choke in a 100w build? might really ghost, but they sound great in 45s and 50watter amps, really open and aggressive, IMHO,
Hi Bluze!
Hi Thousandshirts,Ohhh, didnt see that, I have been away from this thread,did VK not like the MAR100C Choke? I dont favor the MM 7H choke, but I am in the minority with that around here.
vkaxeman
Post
by vkaxeman » Sun Mar 02, 2008 10:54 pm
bluze81 wrote:thousandshirts wrote:bluze81 wrote:Just curious if anybody has tried a 3h choke in a 100w build? might really ghost, but they sound great in 45s and 50watter amps, really open and aggressive, IMHO,
Hi Bluze!
The Mar100C at least in this build just made it more noisy/fuzzy sounding. So far I think I like the stock Dagnall Choke over the Mar100c and the 7h. Still trying to decide.
rockstah
Post
by rockstah » Mon Mar 03, 2008 2:02 pm
yeah the 3h is not it. i like the 7h best. there is more depth in the sound to my ears compared to the stock dagnall. the 7h is my favorite choke.
its a speaker thing that we are hearing at this point. when r u getting new speakers?
vkaxeman
Post
by vkaxeman » Mon Mar 03, 2008 2:29 pm
rockstah wrote:yeah the 3h is not it. i like the 7h best. there is more depth in the sound to my ears compared to the stock dagnall. the 7h is my favorite choke.
G12M - 25 watt Speakers are here. Will be wiring up a PPIMV soon so I can play em without destroying em.
vkaxeman
Post
by vkaxeman » Fri May 02, 2008 11:43 pm
vkaxeman
Post
by vkaxeman » Sun Jul 20, 2008 11:26 pm
Ok now that the LarMar PPIMV is done and working, time to install and wire up the dual tap switch for the dual tap PT that I already have installed. I want to use a 25k Bias Pot instead of a resistor on the switch. Is this correct?
vkaxeman on Mon Jul 21, 2008 5:38 pm, edited 2 times in total.
Stratabuse
Post
by Stratabuse » Mon Jul 21, 2008 2:33 am
Actually, for the bias pot on the switch what you need to do is cut off the leg you have labeled "D" on the pot & use the leg on the other side of the pot to connect to the switch where you have labled "D", & connect "E" as you have it. The rest all looks right.
vkaxeman
Post
by vkaxeman » Mon Jul 21, 2008 5:34 pm
Stratabuse wrote:Actually, for the bias pot on the switch what you need to do is cut off the leg you have labeled "D" on the pot & use the leg on the other side of the pot to connect to the switch where you have labled "D", & connect "E" as you have it. The rest all looks right.
Not sure I understand what your mean? If I cutoff the leg labeled D on the Bias Pot and connect the Bias Pot leg labeled E to the switch where labeled D, then I only have 1 leg of the Bias Pot connected? And regarding "& connect "E" as you have it", I am not going to be using a resistor as in the picture, just the 25k Bias Pot.
Stratabuse
Post
by Stratabuse » Mon Jul 21, 2008 6:16 pm
Hey vkaxeman, sorry if my explaination was a little confusing. If you look at the pot it has three legs, two on one side & one on the other side. Cut off the leg you have labelled "D" in your diagram, now you should have two legs on the pot left, one on each side. Connect the leg that you had labeled "E" to the switch connector you have labeled "E". Now connect the other leg, that's on the other side of the pot, to the other connector on the switch that you labeled "D". Hopefully that's a better explaination. If not, let me know & I can put up a pic of it. I'm not at my home computer right now so I can't at the moment.
vkaxeman
Post
by vkaxeman » Tue Jul 22, 2008 1:53 am
Stratabuse wrote:Hey vkaxeman, sorry if my explaination was a little confusing. If you look at the pot it has three legs, two on one side & one on the other side. Cut off the leg you have labelled "D" in your diagram, now you should have two legs on the pot left, one on each side. Connect the leg that you had labeled "E" to the switch connector you have labeled "E". Now connect the other leg, that's on the other side of the pot, to the other connector on the switch that you labeled "D". Hopefully that's a better explaination. If not, let me know & I can put up a pic of it. I'm not at my home computer right now so I can't at the moment.
I think I finally got it now.
Like this:
Stratabuse
Post
by Stratabuse » Tue Jul 22, 2008 2:04 am
You got it! Now get busy & solder away.
