NOS Tubes = HOLY CRAP!!!!!!!!!!!
Yeah, could be. I don't have enough experience with Super Leads to be able to tell you one way or the other. I can tell you that I have been pulling my hair out modding the circuit in my amp when all it needed was a new OT (to replace the crappy original - either a dog or f'ed up) and some NOS glass to make it sound right.NitroLiq wrote:Doesn't all this also depend on the circuit? I've had friends build amps (modded marshall circuits) that didn't take well to NOS tubes but sounded great with JJs.
Then again, I'm not pushing it as hard as some guys here do. All I know is, the difference in tone is absolutely amazing with my amp.
"Es gibt nichts was es nicht gibt."
- worldoftone
my exp is that the power tubes do play a big part in the sound too. I just changed out winged Cs for RFT in one of my amps and the difference was very clear - It got more 3D! The Cs didn't sound bad but were kinda "flat" compared to the RFT.
Same in one of my other amps (the modded RI). I tried the shuguangs in there for a while. Didn't sound bad at all, but the TESLA that I had in there before (and again shortly after) eat them for breakfast - period!!!
'master keeper wrote:my exp is that the power tubes do play a big part in the sound too. I just changed out winged Cs for RFT in one of my amps and the difference was very clear - It got more 3D! The Cs didn't sound bad but were kinda "flat" compared to the RFT.
Do you know of any good NOS 6550 tubes? I've heard there aren't any. Or if there are, they are probably not good to use.
So, I figured I'd go with Winged =C= 6550 tubes.
- mightymike
Funny you mention that. Cause I'm not a fan of JJs with the ****** 1.5 and MM 1.5 equiped amps, (I thought they were harsh), but they sound really good with those Heyboers 2" OTs George sells, becasue they are not as trebly as a 1.5.NitroLiq wrote:Doesn't all this also depend on the circuit? I've had friends build amps (modded marshall circuits) that didn't take well to NOS tubes but sounded great with JJs.
For the longest time I wondered why George used them, becasue of the results I was getting with other trannys, but once I installed one of his 2" in an amp, I found they sound great with that tranny.
YMMV
Re: NOS Tubes = HOLY CRAP!!!!!!!!!!!
No one has picked up on that one yet, although I was not sure how to describe it either (Fischer? Larry's mod of Fischer???novosibir wrote:Is there something I've overlooked in this forumsjfhudak wrote:I was thinking about Rockstah's PPIMV, but I don't know now, I might just leave it as is!![]()
Which one is that?
Larry
Which one is that?
Larry
Servus Larry -
Halt zur
I don't know about the NOS glass, I do run the Philips 12AX7WAs in my JCM 800 with good results, and in V1 of my '69, but honestly, I am also pretty happy running GT mullard copies or even those Tung sol reissues...You should know, however, that I run pedals in the front, so that may have something to do with it...the one big difference I have noticed is that with the Mullard Power tubes, the pins fit PERFECTLY in the saddle!!! Made for each other!! But I can't find a set of Xf2s that don't make mechanical noise???
68 Marshall JMP 100 Plexi
69 Marshall JMP 100 Plexi
71 Marshall JMP 100 Metalface
66 BF Fender Pro Reverb
67 BF Fender Super Reverb
None of the stores around here have the GT Mullard copies so I haven't tried them yet. However if my experiences thus far with GT are any indication, I won't be spending my money on them any time soon.Bunnest wrote:I don't know about the NOS glass, I do run the Philips 12AX7WAs in my JCM 800 with good results, and in V1 of my '69, but honestly, I am also pretty happy running GT mullard copies or even those Tung sol reissues...You should know, however, that I run pedals in the front, so that may have something to do with it...the one big difference I have noticed is that with the Mullard Power tubes, the pins fit PERFECTLY in the saddle!!! Made for each other!! But I can't find a set of Xf2s that don't make mechanical noise???
I liked the Tung Sols as well, but I had two sets go south on me so I don't intend to spend any more coin on them either. They sounded great for about an hour, and then bought the farm. Not good.
Using pedals does make a huge difference. I didn't start noticing the deficiencies in the newer tubes until I ditched my pedals and started trying to use the amp the way it was. Then all kinds of stuff popped up, and not just the tubes but the OT, and some other weirdness in the circuit.
- wdelaney72
[quote="jfhudak"]Hey Fellers,
Just warmed up the 76 with the NOS pres I got from TubeTramp. . .
OH MY GOD!!!!!!!!
I am taking every new production tube that I own to the shooting range next weekend. They SUUUUUUUUUUUUUUUCK compared to the Sylvania and the two RCAs I'm running now!
Wow. My amp sounds VERY musical now for the first time since I've owned it. Very sweet indeed. I don't have to fight with my rig to get nice sounds now. I can nail it and get it to break up, or just lay back and still have all that nice chime that I've wanted in my Marshall since day one.
Time to get some NOS outputs!! I was thinking about Rockstah's PPIMV, but I don't know now, I might just leave it as is!
All I know, is that I'll NEVER buy another JJ or GT again. . .EVER!!!
Thank you TubeTramp!
[/quote]
...but now the CRUX of the matter: WHICH NOS pre's. Here we go again...trial and error ? $$$$$$$$$.
OH MY GOD!!!!!!!!
Everything is trial and error. I've wasted more money buying new production tubes only to be greatly disappointed than you can imagine. I bought ONE set of NOS Sylvanias and RCAs and they took my amp the rest of the way.PCollen wrote:...but now the CRUX of the matter: WHICH NOS pre's. Here we go again...trial and error ? $$$$$$$$$.jfhudak wrote:Hey Fellers,
OH MY GOD!!!!!!!!![]()
What works for you? Who knows. That's for you to decide. Me? I like what I hear so far, and I'll most likely experiment with others but for now I am really starting to get what I want out of this rig and the NOS tubes are a large part of that.
As to the money I spent, let's just say I would have spent close to that for some of the more expensive new production tubes, which sound like crap.
For me at least, NOS tubes are no longer just snob appeal. They really do work and sound better!
YMMV
- Wicksy
