Thanks I cleaned it up but I just can't fix the Volume 1 problem, I took it out and cleaned it up but it didn't make any difference, any suggestions?
Thanks,
Vahid
Plexi Crankling & Squealing Noise
- vahid_vs
Re: Plexi Crankling & Squealing Noise
The world is full of Kings and Queens
Who blind your eyes and steal your dreams
The sound through the pot when on 0 is entirely normal - do not try to get rid of it - you will failvahid_vs wrote:Thanks everybody, after changing the power socket with a new one, and shielding OT primary wire, the noises went away.
Now I'm trying to fix the problems the amp had before, when I close the Input I volume all the way to 0, I can still here the sound of guitar, and when I hit the the standby switch to off it makes a popping sound.
The pop can be helped by a snubber cap (1000v 0,05uF) between the HT fuse tip and ground. Some amps also benefit from a 4k7 or 5k6 swamp resistor between each output valve grid wire (usuallly a green and an orange) and the socket. Look at some of the builds and you will see them.
The snubber is the brown Hunt's you see here:
