He sent me the pics. This is the left side of the board and then I cut out a close up of pot side. It has the same pins that mine has.
The original pic is 3072x2304. Sure it's had a few mods and repairs but I'd say this is the way it came wired from the factory, like mine.
So I have to conclude, at this point is:
1) My amp is original and came from the factory this way.
2) It has not had "extensive work" and the circuit board has never been out.
3) It has had some minor repair work and some minor mods.
4) Is the wiring sloppy? Yes! And probably why it was humming? Yes!
5) Do I want to go and change it if it's original? No.
Then there is the question as to why.
I bet that they tried this for a VERY SHORT time in an effort to speed up production and then gave it up. Just guessing.
PS: No hard feelings to any of you guys, this just something I need(ed) to research.
Scott
Look at the bare pin lined up with the 1 watt resistor and then go back and look at the picture of my circuit board and you can clearly see that they are the same.
demonufo wrote:maxwedge572 wrote:
Well, look at this picture here and see how that the red dye on the board mounting posts have not been torn up. How would someone install these supposed turrets, which are in fact not turrets but snap on terminals, without removing the board and damaging the dye? I have some pictures of one other marshall that has the same type of terminals and the wires don't run through the holes. I've had this amp since about 1980 and if anything major was done to it, like you say, then it was done before I bought it. I'm fairly certain it's a 1974. The serial # is 5024F
One thing I'm absolutely certain about.
That amp never left the factory new with that one 'hot pink' wire installed.
I'm with Neil though, that's had extensive work done, and they both could've been done better.
