Zero Loss FX loop got blown up. Help with parts ID.
Posted: Fri Sep 24, 2021 6:06 pm
Due to chipped enamel on a screen resistor, the Metro zero loss effects loop in my 2203 got toasted with screen voltage (430 volts or so...) so I took it out to repair.
Fortunately there's not much in the way of silicon devices to blow up.
I've replaced both transistors and have been checking diodes. I found a blown up 1N4148 next to one of the transistors,
and next to that there are two more diodes I intend to replace because I suspect they're damaged even though they read as diodes. But I don't know their type and haven't found a cross reference. They've got the OnSemi logo and the other markings are 24 and 28. I have not found a cross reference for this type.
So, what type of diodes are these?
Either tell me, please, or maybe provide a schematic?
If I replace them, then I'm pretty sure the loop will work again. I'll reinstall it after that's done.
The loop MAY be OK now but I want to replace those two diodes no matter what. Cheap insurance.
