How hard is to convert a JTM45/100 Metro 66 specs into a 67?
Kazhi
Post by Kazhi » Sun Dec 23, 2012 7:10 pm
Can it be done and how hard is it?
mightymike
Re: How hard is to convert a JTM45/100 Metro 66 specs into a
Post by mightymike » Wed Jan 02, 2013 7:40 pm
I'm not sure if there's a huge difference in the 66 2" Jtm45/100 OT and the Black flag 67 2" OT, but If you're looking to convert it to Black Flag/ 10000 series/67 spec, you could start by converting to EL34 by changing the bias range resister to get into the right range. The difference in PT is a different story. The original 66 had a 550v pt, ( The PT I bought from George for my JTM 45/100 kit was 500v) I can't remember what the typical Black Flag / 10000 series plate voltage is, but 500 will just be a little high..Other than that the values are pretty close. Just a different layout mostly. I say just change the bias range resister, put some El 34's that will handle 500v and see if you like it.
mightymike
Post by mightymike » Fri Jan 04, 2013 6:59 pm
Maybe someone in the know on the OT impedences, and any differences, can chime in
waggclan
Post by waggclan » Wed May 15, 2013 11:51 am
I don't believe it involves changing the iron. Investigate an then change out some cap and resistor values. Your current PT and OT should get you there. :jimi:
Big Mike
Post by Big Mike » Thu May 16, 2013 8:09 am
It absolutely needs a different OT unless you want to compensate and mismatch impedance.
And ditto mike on the power trans voltage.
Sorry Steve...
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
Post by Roe » Thu May 16, 2013 2:06 pm
for early 67 you only need a 1202-119 Ot and 4xel34
