Octava sounding high notes?
Posted: Mon Nov 12, 2007 9:40 am
Ok. Heres the deal.
I noticed the other day while playing around the 13 fret and up on the A string that it sounds as if Im playing through a octava pedal. It is almost a warbly type sound.
It does occur on other strings also, but it really stands out on the A.
I have a 100 watt metro into a V30. No pedals, I do have a THD set to -8db.
I tried turning attenuator to -4 and 0 it seemd to help a little.
I haven't removed it from signal path completely though.
And it seemed when I turned the volume on the amp down a bit it helped also.
But it still seemed that the doubling effect was still there but not as bad.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
