For those who have a Metropoulos '68 Series ...
- cole
I have one - love it too, but is anyone besides me noticing that the chassis ends are 'tweaked' a little?
I expected that the ends of the chassis are neatly bent as I have seen on many of the kit builds. Is this a common occurance?
The attached pics are not the best quality, but here is what I am talking about...
The amp was shipped in a double box (packed very well) and the shipping carton was in great shape - don't know if it may have been rough handling during shipping or otherwise???
Cole
Cole
- (562.83 KiB) Downloaded 188 times
- (664.95 KiB) Downloaded 237 times
Les Paul Classic, Les Paul Standard Faded, Fender American Strat
Jackson Custom Shop Strat s/n 1226
JMP 2203, JCM 800 2205, Metro JTM 45
Metropoulos '68 12 Series s/n 12026
Marshall 1960 A/B 4 X 12's
- jbzoso2002
- cole
Yeah, they are okay...the OT mount is not a dead 90 degress but does not looked stressed.
I am waiting on confirmation from George if the chassis was like this before shipping.
Breaks my f**kin' heart really - I love the amp - I wanted one that I would keep for life that was a prime example of a Metropoulos 68 spec.
Guess this is not meant to be.
Cole
Cole
I just looked at my metro chassis there does not appear to be spot welding. I am not sure how they join the metal together. My 70's marshall chassis had a weld or brazing that ran the whole length of the seam. Looks like damage in shiping the amp from a failure of the metal joining. Hope all is resolved to your satisfaction.cole wrote:Yeah, they are okay...the OT mount is not a dead 90 degress but does not looked stressed.
Cole
Take care
Dan
You could bring it back in with clamps and get a small tig weld to attach it the heat is concentrated with TIG and you could do it inside the chassis so you would not see it and that would hold perfect. It would not take much weld to hold that fit up.
You would not have to return the amp. Just an idea, but I weld so that may not be an option for you.
Hope you get it worked out.
May be able to just clamp the ends in and then heat the radius with a small propane torch. That should take the spring out of it when you take the clamp off. This is steel right? Hate to see you melt your chassis
EDIT: Actually forget that .I thought the whole piece was bowed out but it looks like just the one side. I'd go with a tack weld myself I think.
- cole
I had a chance to think it all over and I have a plan...actually I was succesful in getting the side that had the bend back into shape using a big C clamp and some wood blocks to prevent scratching the chassis.
That part came out very well. The remainder of the job will be using a metal epoxy (these chassis are epoxied at the folds???) to redo the folds at the chassis ends. That should be a piece of cake.
The reason I am doing this is because this is the second amp George sent me
and regardless of how well it's packed the fu*kers from USPS and Canada Post collectively still manage to do some damage.
I still have the OT at a slight 1-2 degress of tilt that I will have to deal with.
I will probably get my next Metroamp by flying to George's shop and spending an afternoon at Burton, or wherever George is located when the next one is ordered.
You cannot honestly know what it's like to anticipate this beautifully assembled hand wired amp coming to your door and then open it and find this happening - the second time!!!
I always have the option to return it but I cannot bring myself to try a third time - the damage here is quite repairable and the next time it could be worse, so I'm keeping her.
I will post pics of the repairs when completed.
Cole
Cole
Dang Cole thats a bitch, dont blame you for not wanting to send it back, everytime I have shipped a 100w Marshall style amp, no matter how well you pack them the output transformer or something gets bent, it happend to my 12000 clone coming back from Flames for a check up when I first built it, also I had Flames black flag build and when I shipped it back it really was tore up by UPS, so dont send yours,fix her and play it,awsome amp,
bluze
- Flames1950
That sucks!
Since we're trading stories. I bought a 50w build from a guy- beautiful build and top notch parts. Had the welded steel chassis. He packed it better than could have been expected- even using blocks to support under the tranny to prevent damage. When it got here it looked as if UPS had dropped it 6 feet on to one end. They managed to crack the corner welds and have both ends peices bent in the direction they dropped it. The kicker- UPS rejected the insurance claim saying their regs say there has to be at least 3" of packing surrounding an object. This guy had shipped the thing packed in a wooden crate (supported with the blocks under the tranny) surrounded by 2" of foam then surounded by a heavy cardboard box and they still said it wasnt their fault. It they drag it behind the van is it their fault then?
Re: That sucks!
UPS always says they wont cover the claim, every time I have filed claim they say no, then protest it and they pay, this has gone this way for me about half dozen times with shipments at my store.kefestvog wrote:Since we're trading stories. I bought a 50w build from a guy- beautiful build and top notch parts. Had the welded steel chassis. He packed it better than could have been expected- even using blocks to support under the tranny to prevent damage. When it got here it looked as if UPS had dropped it 6 feet on to one end. They managed to crack the corner welds and have both ends peices bent in the direction they dropped it. The kicker- UPS rejected the insurance claim saying their regs say there has to be at least 3" of packing surrounding an object. This guy had shipped the thing packed in a wooden crate (supported with the blocks under the tranny) surrounded by 2" of foam then surounded by a heavy cardboard box and they still said it wasnt their fault. It they drag it behind the van is it their fault then?
- yngwie308
Cole,
That's what happened to my f%$#&*g HW after FedUp got through with it, in the stock shipping container.
Mine had upon detection been dropped 'light' or non transformer end down, piling all the weight onto the input end of the chassis, busting open my end corner as well, the pre-amp valve covers rollong around in the head box was the first clue and the tit on one of the 12ax7's was broken off.
So I am saving for my 1/4" ply, 2" foam custom Anvil case, so when my head returns to Flint, it will come back home to stay
It made it all the way from England to Guitar Center in Az, relatively unscathed and then to Michigan, but the trip back...
