Gents,
I have been having problems with my Weber 6m45p recently and looking in it, its a total spaghetti mess. Everything is way too tight in there..small chassis. I want to rewire it neatly and use one of George's PTP kits. Can someone tell me what the dimensions are of the 50 watt chassis? I know my laney 50 watt seems to be inside a 100 watt chassis and i am wondering if I should go with a 100 watt chassis or is the 50 big enough? Would the weber 6m45P essentially be what they call a small head or small box Marshall? It was a bloody pain to work in there and i'd like something neat that i can easily make changes too moving forward.
Thanks..
50 watt chassis in metro store
- Flames1950
Thanks for the info. Are they deeper at all? It looks as if there is more room between the tube sockets and the board... I guess I might want to consider the PTP board that is PCB board replacement size then. Also, if not that much more room then hell, I should take the money for the chassis and faceplates and drop it on a mercury output tranny!
