Hey guys...When I power up my 50 watt build I get snap,crackle, pop. I traced it to V3 by pulling pre tubes one at a time. All voltages check out except pins 3 and 8 on V3. I get a hot reading of 95 on those instaed of the 35-40 that I should be getting.
The poppiong does stop when I touch either signal pin with the meter probe. Any ideas?
Kevrockitt
Help..Rice crispies in V3 of my 50 watter.
- rockstah
Re: Help..Rice crispies in V3 of my 50 watter.
try reheating the solder joints on the socket and check all the connections to the board.kevrockitt wrote:Hey guys...When I power up my 50 watt build I get snap,crackle, pop. I traced it to V3 by pulling pre tubes one at a time. All voltages check out except pins 3 and 8 on V3. I get a hot reading of 95 on those instaed of the 35-40 that I should be getting.
Kevrockitt
Thank you!!! That did it. I really appreciate the advice!!!
Amp sounds great but inputs are a little noisy. Could that be the CC resistors?
