Hi to everybody. I am new here, but have been following the forum for a while. Alot of great info and everybody helps everybody, very nice.
George, I will be buying a 50 watt kit in late March. I wanted to know if you will be doing a step by step for the 12000. Second question, will the chassis of the 50 watt plexi allow room to add an fx loop and a master volume ? Anybody can answer the second question if you know. Thanks
STEP BY STEP FOR 12000 SERIES
- thetasigma
I started with a JTM-45 kit then built a 12 series. The weird thing being, I actually found the 100watt to be a bit easier to build because of the extra space the chassis allows.he 12 series may be a bit much for my first build. The only thing I have ever done is install a MV on a plexi reissue and biasing amps.
-Nathan
"Eagles may soar, but weasels don't get sucked into jet engines."
- mwm523
But you also had the experience of building the JTM 45 under your belt.thetasigma wrote:I started with a JTM-45 kit then built a 12 series. The weird thing being, I actually found the 100watt to be a bit easier to build because of the extra space the chassis allows.he 12 series may be a bit much for my first build. The only thing I have ever done is install a MV on a plexi reissue and biasing amps.
I had a similar experience with my builds. I did the JTM 45 first, and then recently did the 50 watt. I was much more comfortable and had much more confidence building the 50 watt.
-Mike
- thetasigma
Won't argue with you on that one. However, my point being that with the larger chassis of an 100watt it seems to me a bit easier to route wires, and gives you some more elbow room when soldering components.But you also had the experience of building the JTM 45 under your belt.
-Nathan
