Post
by novosibir » Sat Apr 21, 2007 2:12 pm
That's what I've said!
Imagine what happens, when you want to change the mains fuse, but you haven't removed
the AC cord from the wall and also not from the amp.
You're holding the fuse holder cap with a new fuse in it, one finger is touching the metal
threat. Now you try to fiddle in the fuse, while the other end of the fuse is touching the side lug
inside the fuse holder (where in this case the L from the AC inlet is connected to)
- and your other hand is resting on the amp's chassis...
... any further questions?
Larry
