Allen Bradley resistors and the 50 watt kit
Post by VelvetGeorge » Mon Dec 03, 2007 2:40 pm
In the diagram, the bottom input is the hi sens jack. When you plug into it, there is a 1M from tip to ground and 34k of series resistance.
When you plug into the low sense input, there is 1.068M from tip to ground and 68k in series.
toner
Post by toner » Mon Dec 03, 2007 2:44 pm
The switching jacks cause the parallel connection I mentioned. Here's a diagram.
(7.26 KiB) Downloaded 459 times
rockstah
Post by rockstah » Mon Dec 03, 2007 2:47 pm
VelvetGeorge wrote:In the diagram, the bottom input is the hi sens jack. When you plug into it, there is a 1M from tip to ground and 34k of series resistance.
but.. but... both resistors on the board measure 33k.. further more i have tried a 33k and 68k right on the tube socket with a 1m on the jack and don't hear the difference i hear using the high and low stock jack configuration.
johnnymenudo
Post by johnnymenudo » Mon Dec 03, 2007 2:54 pm
So, where do we use our four 1 M ohm, and two 100K resistors that come with the kit? LOL
JM
rockstah
Post by rockstah » Mon Dec 03, 2007 2:57 pm
johnnymenudo wrote:So, where do we use our four 1 M ohm, and two 100K resistors that come with the kit? LOL
JM
1 for the high input on channel 1 - one for the high input channel 2
and two in the phase inverter circuit on the board. look at a digram of the main board.
100k's are plate resistors. of course there is one more 100k on the cathode follower of v2 ( v2b) and one in phase inverter.
toner
Post by toner » Mon Dec 03, 2007 2:57 pm
JM
Sorry man! I took this into left field (again). :oops:
johnnymenudo
Post by johnnymenudo » Mon Dec 03, 2007 3:10 pm
JM
It's all good I am just not as techno savvy as you guys so when I try to describe where the resistors might go, I have to say things like the post by the blue wires that goes to 1 and 6 of V1 (100K), or the pins by the green wires that go to 1 and 6 of V3 (1M).
rockstah
Post by rockstah » Mon Dec 03, 2007 3:14 pm
johnnymenudo wrote:
JM
look at the board diagrams on your metroamp CD.
johnnymenudo
Post by johnnymenudo » Mon Dec 03, 2007 3:24 pm
rockstah wrote:
johnnymenudo wrote:
toner wrote: Sorry man! I took this into left field (again). :oops:
look at the board diagrams.
Right, but the diagrams for George's recommended replacement points for the Allen Bradley resistors do not specifywhere you should put all of the 1M and 100K resistors that come with the NOS kit. I didn't want to just randomly guess which IM resistors and 100K resistors I should swap out.
rockstah
Post by rockstah » Mon Dec 03, 2007 7:36 pm
