I got this Head Shell from Chris Uff here in the UK. I ended up putting my West Coast modded 1987 into this shell and this 69 spec 1987 went into the StoneAge head shell.
Specs;
It's pretty much a stock 69, only a few slight variations.
Split Cathode
220uf / 820r on V1
.68uf / 2.7k on V1
No .68uf cap on V2
.0022uf on second coupling cap
500pf caps on mixer and tone stack
47k negative feed back on 8ohm tap
2x 8.2k 2watt preamp dropper resistors
5000pf bright cap
Filtering;
100uf Mains
50uf Screens
50uf Phase Inverter
32/32uf Pre amp
Tubes;
pre amp = NOS Mullard Ecc83
power = NOS Svetlana Winged C
So It sounds great, needs more playing in but it's great. This will pretty much be my number 1 amp.
