you risk oscillation and redplatingCoot Boy wrote:Doesn't tying your OT primary and secondary wires together create some kind o noise/hum? Sure I read that somewhere.
JMP50 68-69' specs (work in progress...)
Re: JMP50 68-69' specs (work in progress...)
- leonard.gulyas
Dear Roe,Roe wrote:you risk oscillation and redplatingCoot Boy wrote:Doesn't tying your OT primary and secondary wires together create some kind o noise/hum? Sure I read that somewhere.
Can you please explain to me what are these terms and what they cause in terms of sound/operation.
Regards
sorry, try to search and to readleonard.gulyas wrote:Dear Roe,Roe wrote:you risk oscillation and redplatingCoot Boy wrote:Doesn't tying your OT primary and secondary wires together create some kind o noise/hum? Sure I read that somewhere.
Regards
sorry perhaps this will help:http://forum.metroamp.com/viewtopic.php ... oscilationRoe wrote:sorry, try to search and to readleonard.gulyas wrote:Dear Roe,Roe wrote:
Regards
http://forum.metroamp.com/viewtopic.php?f=4&t=16511
- leonard.gulyas
Thanks Roe for the links.
So how much distance between OT input and output cables is adequate?
Regards
Regards
- leonard.gulyas
So the build continues after the turret board finally arrived (after 3 months
As Roe and others suggested I untied the OT Primary and Secondaries to avoid further problems.
I installed the HT Fuse (internal one due to lack of real estate).
I cabled the turret board as the kit instruction suggested.
I did a fit test with the turret board, so here it is:
I'll keep you posted as the build continues tomorrow.
- leonard.gulyas
Super clean work so far, candy to the eyes!!
I'd minimize parallell wires, esp. the green and blue ones in the preamp and the primary and secondary of the OTleonard.gulyas wrote:Updates:
can somebody please check if there is any overlapping cables can cause some problems because there is so many of them?
[/url]
Regards
- BrianH
Sorry it took so long, Leonard! Your address changing, board being returned to me, and then a Customs delay really made it rough.
- leonard.gulyas
I really have to say Brian it worth the wait and you are a super nice guy to deal with.
- axeman
Wow, it is turning out very nice. Good job. We're did you get the switches? I would like to use some of those on my next builds.
Art
Art
- leonard.gulyas
Thanks for the kind words, I PM'd you about the switches.
