unmusical overtone trouble
- rgalpin
when i hit an open A string i am getting a rattle-ish sounding note that seems very close the root A - it rattles underneath in a nasty unmusical way that destroys the focus and sweetness of the A.
i've actually heard this on many guitar to varying degrees - but it has become very noticeable on my main guitar and it's driving me nuts - i have tried everything filing the nut - filing the saddles - stuffing a rag around the springs on the trem - filing the fulcrum where the trem contacts the post - i am all out of ideas.
anybody ever have any experience with this sort of thing?
- JimiJames
- rgalpin
whatever it is - it's riding on the note produced by the open A string - but it's subtle enough that I can make it tolerable by lowering that side of the pickup.
could the truss rod actually be vibrating/rattling inside the neck? i have a warmoth 23 3/4 strat conversion neck - it has a truss rod adjusment screw on the side of the neck down at the heel where it connects to the body for easy access.
maybe i'll just try tweaking the tension on that bad boy to see if it makes a difference.
i'll also check where the saddle screws hit the base - that is exactly what i envision the source this rattle to be like - a metal on metal "zzz- zzz" thing that compromises the stability of the note.
awesome input! thanks. i'll post my findings.
- 45auto
truss rod could be rattling inside neck. my boogie bodies (much like yours) had this very prob.
- JimiJames
- 45auto
well, the damn thingalways had a bit of a reverse bow, so i had to keep the truss as loose as possible, but snug enough to not rattle. there were actually times that i stuck it into a dresser drawer face down & let the neck bow the right way! i believe you can build a jig & apply heat & get some results? i'm not the expert luthier really. just do alot of improvising!
