I just installed the Metro C1998 OT in my 1959SLP RI and it sounds fabulous. Alot more clear, smoother overdrive, faster attack, stout, slightly punchier and very rich in harmonic tone. I've heard it takes 24 - 30 hours to break in. What should I be listening for? Does it loosen up...relax alittle...??? Get stronger? Just curious thanks.
Great Job George!
Also the next thing is the PTP board.
Already made it a shared cathode which made it sound slightly fatter with slightly less overdrive. Does adding the PTP board make it sound even more smoother....sweeter? What in a general sense for those that did it does the PTP board start adding to the tone? Thanks for you replies!!
Also a huge shout out to Larry for the V1 (pin 1) to ground for draining the caps. Did everything safely...phew.
Transformer Break In
- novosibir
Re: Transformer Break In
The sound becomes still sweeter, fatter and warmer. If you maybe feel the sound a bit edgy with the new OT, that will get lost over the first 20-30 hours.Hammer Down wrote:I just installed the Metro C1998 OT in my 1959SLP RI and it sounds fabulous. Alot more clear, smoother overdrive, faster attack, stout, slightly punchier and very rich in harmonic tone. I've heard it takes 24 - 30 hours to break in. What should I be listening for? Does it loosen up...relax alittle...??? Get stronger? Just curious thanks.
Larry
