Switching the dual voltage PT taps
- VelvetGeorge
- Site Owner
Let's get all the info in a thread for this. I'm getting a lot of emails.
The theory behind this is:
You switch the full high voltage supply lower taps in the secondary wind.
About 40 volts less AC supply to each side of the diode bridge results in about 100 volts less DC.
So (4) wires from the high voltage secondary are switched going into the rectifiers.
When the voltage is dropped, we also need to lower the bias voltage to maintain our intended idle current.
In the diagram I accomplish this by switching an extra resistor into the bias voltage supply from the PT.
The value of this resistor should be adjusted to make your tubes bias at the preferred current in the low voltage setting.
VG
VG
- (101.63 KiB) Downloaded 7741 times
- 5150loveeddie
Cool info VG, thanks
- 5150loveeddie
- VelvetGeorge
- Site Owner
- 5150loveeddie
Let me know if this is a little to sexy!! I'll change it!!!!VelvetGeorge wrote:Nice avatar!! Thank you JF!
VG
- Guitar Adjuster
- Flames1950
- antosimoni
- Flames1950
- antosimoni
hi this is mine, could you please point me where this 27K res have to be placed??? lots of thanks if you can help me...Flames1950 wrote:The 27K should already be on the turret board in the 1959HW.........that's part of the bias section which was already there.antosimoni wrote:George,
sorry but to me its not clear where I've to put that 27K res in my 1959HW, any help will be appreciated, thanks a lot to every1
thanks a lot for any advice will come in
- wdelaney72
- wdelaney72
