Drake OT's for 100 Watts
All about iron and copper.
Post by VelvetGeorge » Thu Jun 22, 2006 10:32 pm
Drake 100 watt output transformers:
11/65 1202-84 2" core 4K primary 8,16 and 100V taps
02/67 1202-119 2" core 1.75k primary 8,16 and 100V taps
06/67 1202-132 2" core 1.75k primary 4,8,16 taps
Also, the Dagnall C1998 seems to date to 11/67.
Post by Flames1950 » Thu Jun 22, 2006 11:21 pm
From the primary impedances only the 1202-84 is a KT66 tranny, right? The others are EL34?
I guess I was assuming your '66 was a KT66 amp....is it set up with EL34's right now?
Brian Wallace
Supporting Advertiser
Ot's
Post by Brian Wallace » Thu Jun 22, 2006 11:25 pm
Yes, the 1202-84 is the only KT66 OT but either tube will work just fine with these transformers, give it a shot and see what you think.
The C1998 is more of an August OT IMO. ;)
Patience is a virtue.
Wallace amps
Wallace forum
Post by Flames1950 » Thu Jun 22, 2006 11:31 pm
Nah, I'll stick with the KT66's on your 1202-84 clone in my Super PA.......I'm just glad you used a four ohm tap instead of the 100V tap!
Re: Ot's
Post by VelvetGeorge » Thu Jun 22, 2006 11:59 pm
Brian Wallace wrote: The C1998 is more of an August OT IMO. ;)
Really? I thought someone had confirmed that date with Dagnall. Of course, it's just what I heard- I can't back it up.
Marshall Growl
Post by Marshall Growl » Sat Apr 07, 2007 6:34 am
Is the transformer in the Marshall super 100JH specifically made around the kt-66 tube? Also, in this amp would one speaker jack put out 100 watts at 16 ohms on the selector? Or are you supposed to half it when using 1 cab?
Children of the Grave!
Ralle
Re: Drake OT's for 100 Watts
Post by Ralle » Tue Dec 04, 2012 12:56 pm
I found a forum called Marshall Road House, and there's one guy ( moderator ) that says the Drake 1202-132 ot has a primary impedance at 2.2k...
Here's what he says:
Drake 784-103 (Primary: 8k ohm, Secondary: 8, 16 ohm, 100V line) JTM 45, JTM 45/100 (dual output transformers)
Drake 784-128 (Primary: 3,5k ohm, Secondary: 4, 8, 16 ohm, buried 100V winding) JMP 50
Drake 784-139 (Primary: 3,5k ohm, Secondary: 4, 8, 16 ohm) JMP 50
Drake 1202-84 (2" Stack, Primary: 4k ohm, Secondary: 8, 16 ohm, 100V line) JTM45/100
Drake 1202-119 (2" Stack, Primary: 1.75k ohm, Secondary: 8, 16 ohm, 100V line) JTM 100 (Black Flag) , JMP 100
Drake 1202-132 (2" Stack, Primary: 2.2k ohm, Secondary: 4, 8, 16 ohm) JTM 100 (Black Flag), JMP 100
Drake 1209-3 JMP 100 (2" stack, used on a few early 70s 100 watt amps)
Dagnall C1998 (1.5" Stack, paper bobbin, Primary: 1.75k ohm, Secondary: 4, 8, 16 ohm) JMP 100
Dagnall C2668 (1.5" Stack, nylon bobbin, Primary: 1.75k ohm, Secondary: 4, 8, 16 ohm) JMP 100
What do you guys think of this?
Brian Wallace
Post by Brian Wallace » Wed Dec 05, 2012 7:22 pm
The 132 has a 1.75k primary. That's what I think. :)
Wallace amps
Wallace forum
Post by neikeel » Thu Dec 06, 2012 7:19 am
Brian Wallace wrote:The 132 has a 1.75k primary. That's what I think. :)
What do you know about it Brian? :roll:
Whilst you are here my recollection of my old '71 JMP100 was the OT was 1 1/2" 1202-99
http://forum.metroamp.com/search.php?st ... l&start=45
and the 1209-3 is a 2" PT.
So I think your source (moderator?!) is less than reliable!
Brian Wallace
Post by Brian Wallace » Sat Dec 08, 2012 10:02 am
Hey Neil,
The 1202-99 and 1209-3 are Drake copies of the C1998 and T2562 transformers.
Wallace amps
Wallace forum
Post by neikeel » Sat Dec 08, 2012 10:19 am
Yes that would fit.
I thought the Drake better than a 2668 or 2373 but still in same style as a 1 1/2" Dagnall, maybe a little more together?
bill bokey
Post by bill bokey » Sun Dec 09, 2012 9:23 am
Brian Wallace wrote:Hey Neil,
Glad to read that as I have a 1202-99 sitting on a shelf.
When I have a minute (or 60) I'll replace a Marstran C1998 with the Drake 1202-99 in my SL clone. Wonder if I'll hear an improvement.
Post by neikeel » Sun Dec 09, 2012 12:11 pm
Let us know :wink:
bill bokey
Post by bill bokey » Mon Dec 10, 2012 7:34 am
I will and I'll also record some before/after clips.
novosibir
Post by novosibir » Wed Nov 20, 2019 9:20 pm
When? Still within this century?
