Need Wiring Help With Jtm50 Classic Tone Pt #40-18054
Just about to Solder Leads and could use confirmation so i don't mess it up. I've Hooked up the Green wires to the V4 and grounded the Grn/Yel and Red/Yel . According to the Diagram instructions on the bottom i should use Red-Red/Yel-Red for a tube rectifier but the verbal instructions i got were to use Orn/Orn which is for a SS rec and i'm going to use Red/Red for the Tube rectifier instead. I'm Taping off the Gry, Wht, Red/Blu, and i am assuming the Yel/Yel too since its not being used according to the directions. I have Blk/Brn together and Blk/Wht and Brn/Wht together. So i am going to solder the Reds to the Rectifier Pins 4 and 6 . My confusion is the primary wiring and where to wire the Blk/Brn and Blk/Wht - Brn/Wht. Do these wires get soldered to the same lug or are they split up? The Ceriatone PT Layout shows a wire from 0 going to the AC plug, H1 and H2 going to the Rectifier on Pins and the wall voltage in going to the Power Switch . Is the Blk/Wht - Brn/Wht H1 and H2? Do i solder the Blk/Brn to gether at the lower Power switch lug? Which wire is 0? Thanks again for any help i really appreciate it .
Re: Need Wiring Help With Jtm50 Classic Tone Pt #40-18054
Are you wiring for a 120, 220 or 240 input voltage? What model number is your PT?
