One question about the Power Brake...
All about iron and copper.
Ralle
Post by Ralle » Fri Oct 28, 2011 11:29 am
Hey guys.
Lokking at the 8 ohm resistor + 1 mH inductor:
If I removed the inductor ( L1 ), wound it be wrong for the load? Is the inductor a part of the load, and needs to be calculated into the load?
Ralle
Ralle
Re: One question about the Power Brake...
Post by Ralle » Sat Oct 29, 2011 6:07 pm
Over 40 wiews and no reply... this must be a hard nut to crack...
SteadyEddie
Post by SteadyEddie » Sat Oct 29, 2011 6:13 pm
I took a quick look at it. It seems that the inductor acts as some sort of filter for the load?
Why would you want to remove it?
Ralle
Post by Ralle » Sat Oct 29, 2011 8:19 pm
I would like to see if the load changes without the inductor in this particular circut...would the load in the powerbrake still be the same ( I know that the highs will go away, but that's not the point here )... Can I still use it the same way, without any adjustments?
