Does Drake 1202-324 PT suits JTM 45 project ?
I could not find any detailed specs for it on the web.
So...
Please, let me know.
Drake 1202-324 in JTM 45 project
Re: Drake 1202-324 in JTM 45 project
The 1202-324 is a Drake power transformer used in the 80's for 50watt Marshalls, typically used in stand up form.
It will give you around 460-470 volts when rectified but you will need to use diodes as it only has a 6.3vac heater (you need a 5v tap for a GZ34 used in a JTM45). They have primaries for 120v, 220v and 250v.
