MM P4550JT-G2 Wiring Question
All about iron and copper.
sebben
Post by sebben » Wed Apr 13, 2011 8:55 pm
I am building a plexi and using the MM P4550JT-Gt that is recommended for the build.
Question is it has terminals on the back and I want to make sure I am correct with the wiring, so I assume the following:
on one side the terminals read and the = is what i believe it is
5 = 5 volts
0 = ?
322 = 322 volts
0 = CT
322 = 322 volts
other side has the following:
COM = Common - for the High voltage
3.15 = 3.15 volts -filaments
0 = ct
Correct?
soundguruman
Re: MM P4550JT-G2 Wiring Question
Post by soundguruman » Mon Jul 18, 2011 4:18 am
You need to state the question differently. What you are asking really does not make sense.
