You have dual primaries that can be hooked up in a number of ways 240, 230, 120, 115, etc... The heater voltage has been scaled to give a better margin with a lighter load. the secondary still has the option for 330VAC so you don't tax the screens of EL34, 6L6, 5881 tube types, and also has a higher 375V tap for big Kinkless bottles. I got rid of the CT so the window can be better utilized for thicker wire (beefed up current rating), and help with a smaller footprint. the 900ma rating suggests the most worse case scenario a quartet of KT88's might pull from the supply under wide open peak conditions, and may not reflect how the company rates the tap.
Separate bias tap, and 18VAC tap for Switching, DC heaters, OPAMP, and CMOS circuitry
Discuss
