Has anyone used an O'Netics PT in a plexi style circuit? Any benefits or limitations?
http://www.c3amps.com/Onetics%20Transformers.htm
My next build will incorporate a stock 1959 circuit (most likely mid 70s JMP) but probably also include a switchable 3 and 4 gain stager as well.
I know the O'Netics deliver ~500v to the plates, which is probably a touch too high for a plexi, but shouldn't cause major issues?
The 76 JMP I currently have from a mate has an unknown replaced but huge PT delivering around 476v to the plates and I am attributing the super sound at least in part to the PT.
O'Netics PT
- kdmay
Re: O'Netics PT
these are known to be big, heavy and stiff sounding. very little sag, unlike originals which sagged about 100v
- kdmay
Re: O'Netics PT
OK, makes sense given they are designed for SLOs.....
Perhaps I'll give the Matrans a go then
Re: O'Netics PT
I have this PT in one of my slo clone builds.
It sags quite a bit, runs pretty hot and is expensive. I would look some where else for a power tranny.
I like the OT.
I like the OT.
- FortinAmps
Re: O'Netics PT
The O'Netics have excellent regulation. I find that they run within the heat specifications. Did you connect the small black wire with the white strip to ground? What's the voltage drop you're getting from idle to full output power?jasonp wrote:I have this PT in one of my slo clone builds.
I like the OT.
Great PT but it won't sag and will not give you the feel of a true plexi.kdmay wrote:Has anyone used an O'Netics PT in a plexi style circuit? Any benefits or limitations?
Cheers,
Mike
- kdmay
Re: O'Netics PT
Thanks for the reply Mike - if the amp comes up sounding an inch of yours, I'll be happy!
I have ended up going with the Martrans set (wanted to retain the plexi vibe and sag), but I am in the process of building an SLO clone with the O'Netics and they are monsters!! Can't wait to fire them up....
- FortinAmps
Re: O'Netics PT
Thank you for the kind wordskdmay wrote:Thanks for the reply Mike - if the amp comes up sounding an inch of yours, I'll be happy!
Brian's Trannies are excellent and should give you exactly what you are looking for. The O'Netics is perfect for an SLO inspired build. I'm assuming that you are going with the O'Netics High Def OT as well.
Cheers,
Mike
