Dagnal color codes
All about iron and copper.
JMPMAN
Dagnal color codes
Post by JMPMAN » Tue Sep 04, 2007 7:01 am
Does anyone know what color wires on a Dagnal 100 watt transformer in a Marshall Super Lead are suppose to be used using 120 V? I'm in the process of putting one of George's PTP's in and want to make sure which wires are correct.
I saw a while back a post related to this, but seem to have a hard time finding. Thx
Myopic Void
Post by Myopic Void » Tue Sep 04, 2007 11:36 am
Did you get the Cd with your kit, it has spec's schematic's, tranny info etc? Best of luck with your build!
Cheers,
Eric
JMPMAN
Post by JMPMAN » Tue Sep 04, 2007 6:57 pm
Thanks. I have looked at the disc and though I have seen the schematics and pics, they are mostly of other brands of PT's. I'd really like a definitive answer concerning the color codes for the primary/secondary for the Dagnall PT model T3556 in my '74 Marshall SL. If I'm overlooking that info on the disc, please correct me.
rockstah
Post by rockstah » Tue Sep 04, 2007 6:58 pm
zis help? Image
or maybe zis one. - Image
JMPMAN
Post by JMPMAN » Tue Sep 04, 2007 7:20 pm
AHHHHH! There we go, that's more like it :D So the PT bottom pic from one of George's kits has the same coloring code as mine? That simplify's things alot. Thanks Rockstah and I've been listening to your tones for a while, good stuff 8)
rockstah
Post by rockstah » Tue Sep 04, 2007 7:22 pm
JMPMAN wrote:AHHHHH! There we go, that's more like it :D So the PT bottom pic from one of George's kits has the same coloring code as mine? That simplify's things alot. Thanks Rockstah and I've been listening to your tones for a while, good stuff 8)
kewl man! the difference here is laydown and stand up - both are georges dual tap PT's.
JMPMAN
Post by JMPMAN » Thu Sep 06, 2007 9:29 pm
After comparing my Dagnall PT and the one you posted of George's, I'm really confused. PLEASE help :cry:
http://www.putfile.com/pic.php?img=6527797
BTW, I'm still trying to figure out how to post the image so that you can see it in the post......
toner
Post by toner » Thu Sep 06, 2007 10:31 pm
JMPMAN wrote:BTW, I'm still trying to figure out how to post the image so that you can see it in the post......
Just go to the putfile page and right-click on the image. Then copy the Address or Location. Then, in your forum message, click "Img", paste the copied image location and click "Img" again.
The code will look like:
Code: Select all
[img]http://img2.putfile.com/main/9/24821235881.jpg[/img]
and the image will appear full size:
You can also copy the "BB" code from the putfile text box below the image and paste it directly into your message to make a clickable thumbnail.
Code: Select all
[URL=http://www.putfile.com/pic.php?img=6527797][img]http://img2.putfile.com/thumb/9/24821235881.jpg[/img][/URL]
and you'll get the thumbnail:
JMPMAN
Post by JMPMAN » Thu Sep 06, 2007 11:44 pm
Thanks Toner 8) Though I'm still confused when comparing mine to Mark's pics. Some of the primary wires I recognize, but others I don't. I'd rather know for sure before I start wiring stuff up. Right now it seems to be one big glob of wires, I might just redo the whole wiring of it, but still need a little more info before I do. Which is not to say that you guys have not been helpful already :wink:
JMPMAN
Post by JMPMAN » Fri Sep 07, 2007 10:33 am
Any takers out there want to try to figure this out? I'm still scratching the ole knogin, especially when looking at the 100 watt build instructions. This Dagnall PT is really slowing down progress :x
