I posted this in the JTM 45 section, but thought it should go here as well...
Any of you guys used this with an RS tranny?
Radio Spares 8/16 DPDT switch
- 6string
- RS OT 8/16 DPDT
- (3.7 KiB) Downloaded 427 times
Hi, I am thinking of it, too...
I was even able to get an 4 ohm arrangement
on a schematic using 2P3T switch,
RS OT looks something mysterious to me,
but I have found, that the 3 wiring diagrams
for 16, 8 and 4 ohm arrangement are basically this:
16 ohm - all three sections in series
8 ohm - one section in series with the other two in parallel
4 ohm - one section in parallel with the other two in series
For me, the most important question is this>
Does it matter, when I connect the sections in different order,
other then the exact one depicted in the schematics
in the transformers section?
Which means - are there another factors that come into play such
as capacitance between the sections or something else?
Well, I have not been able to find any answers to these question really,
so I hope anyone of you could help...
Steve
Steve
...you'd better trust your ears, then anything else...
- 6string
I wrote an email to DST several weeks ago and the following is a portion of Bob's response...
"Keep in mind that all 3 windings are identical so the order isn't all that fussy. You just need to observe the correct polarity (winding start and finish). This applies to the primary as well."
Hope this helps...
I am going to go ahead and try it out on the build that I just started.
Hope this helps...
