wire quest, 1202-118
All about iron and copper.
bluze81
Post by bluze81 » Fri May 25, 2007 9:58 pm
I want to make shure I have this correct on my 50w build power trnsf, wiring? black common to mains fuse, brown 120v to ac switch [usa], secondary red -standby,red-standby, red/yellow center tap? not shure where to connect ct? both green to pin2 and pin 7 ,green/yellow wire to ground. can someone confirm this for me? just unshure where the red/yellow ct connects to? thank you in advance! bluze
Post by Flames1950 » Fri May 25, 2007 10:35 pm
Center tap is still grounded, although the 50-watt w/diode rectifier doesn't put the fuse in line with the center tap typically.
bluze81
Post by bluze81 » Sat May 26, 2007 12:33 am
Thank you Flames!
