Hi all. This is my first post and I am a total noob to amp kits.
So far my first assembly has gone rather well. The few snags that I have had have been answered by forum posts. You guys rock!
Now I am stuck. I am building the 100w plexi and I am on step 9 where I have to connect the PT secondaries to the toggle switches. I think I know what to do with the primaries (miracle!). I have the Heyboer stand up PT and the wires on the left side of the PT are as follows:
2 x solid red wires
2 x solid blue wires
1 x solid white wire (this is the bias tap to PTP so no question here).
1 x solid yellow wire (to positive terminals on filter cap, so no question here).
All other wires I understand.
Q1. The manual says in step 9a: "The red wire from the PT attatches to the lower two terminals of the power switch." What about the other red wire?
Q2. The manual says in step 9b: "The blue and grey wires get twisted together and attatch to the lower two terminals of the standby switch." I have 2 blue wires no grey wires. From a previous post, I was able to decipher that my 2 blue wires should go to the standby switch. Am I correct?
Q3. Where can I find the wiring diagram for this transformer? I have looked through the CD to no avail. I think the diagram would answer my questions.
Any help on this would be fantastic. Thanks in advance,
Ben.
PT wiring help please.
- Flames1950
